D16Z6 into a 91 DX hatch questions??
got a 91 dx hatch plannin to drop in a d16z6 from a junker i got for free. tried a search but didnt find much. my questions are which axles to use, how difficult is the wiring???
If you are using the same transmission the axles will be the same, however, if you want to use an si tranny you will need si axles. The wiring shouldn't be too hard, just wire it for MPFI and buy a VTEC subharness.
or you can activate vtec through a toggle switch
And all you need for the mpfi part is a si resitor box. You can use a teggy one if you like twinkies
EDIT: Isnt the 92+ trannys Hydro trannys?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRCCRX911 »</TD></TR><TR><TD CLASS="quote">or you can activate vtec through a toggle switch
or you can convert to OBD-1 and then all you need to do is throw away the resistor box and solder the wires together.
I think you should be fine w/ the axles that you have. unless they are bad
EDIT: I didn't go into detail about what all is needed but I do recomend buying a conversion harness it's TON's less headache and BlownHatch has very nice harness's + tech support is AWESOME.
also search for d16z6 that's how I found most of the stuff I needed to know
hope you were not reffering to me Ba4
Modified by S9i1R at 10:15 PM 10/12/2004
</TD></TR></TABLE>or you can convert to OBD-1 and then all you need to do is throw away the resistor box and solder the wires together.
sigh
please dont post up info about stuff u dont know about
if u have a si trans u dont have to have si axles
ALL D SERIES axles will fit into ANY DSERIES TRANSMISSION, so if u have a dx just make sure u keep ur dx axles
the only differnce is the outer splines for the axles if u buy si axles, because u got a si trans BUT U HAVE A DX,
ur a idiot wow u got it to fit into the trans but any d series axle will fit but then when u go to put it into ur hub then the si axle wont fit
notes: keep ur dx axles it will mate to any d series trans
i have the same swap, u can convert to obd1 like i did using a jumper harness and p28 ecu
items u need
obd1 ecu
4wire o2 sensor
obd0-91 jumper harness
and wireing up the injectors obd1 style if u choose
ALSO BE4 DOING ANYTHING U MUST CONVERT TO MULTI PORT SINCE U HAVE A DX HATCHBACK
and a toggle switch isnt really recommend, sure u can activate vtec but it wont add the extra fuel just turn it on
everythign from the z6 will work but u have to use ur old drivers side mount, aside from that wiring is the only hard thing but if ur good at wiring should be simple, the whole swap is cake and shouldnt be that hard sicne ur using all ur old parts hubs/shift linkage/mounts etc
good luck i love my z6 and when it hits the Vtec Its MaD LOuD YOoO!, im planning to boost mine
items u need
obd1 ecu
4wire o2 sensor
i need help wiring. i have a 88 crx DX! swapped in a d16z6. the problem is...i want to use OBD1 injectors that are on my intake manifold. u guys tlak about just cut the injector resister off and solder. but i dont have a injector resister to start off with....all the wiring info for my swap would help. thanks
EDIT: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Why, All you need is the resistor box and injector plugs..</TD></TR></TABLE>
Sorry,
thanks for informing me as I was not aware since I started w/ the Si
Modified by S9i1R at 12:33 AM 10/15/2004
Sorry,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R »</TD></TR><TR><TD CLASS="quote">you need to convert it to MPFI. start by getting a harness from a Si or a Hf...</TD></TR></TABLE>
jackmode9366
Apr 29, 2008 08:54 AM
95PreludeSi
Mar 11, 2005 12:44 PM
