B20B/B18B Pistons...What should I use?
Old Oct 12, 2004 | 06:07 PM
AutoFabProductions's Avatar
Default B20B/B18B Pistons...What should I use?
Does anyone know what pistons I can use on a b20b block with b18b head? everything on the internet is figured for a b20 block with a b16 head. im looking to get 11:1 compression with wiseco pistons but i dont know what ones to use since they base everything on a crvtec setup. if you know how i can figure this out or know off hand please let me know.
Old Oct 12, 2004 | 07:55 PM
eg_type_r93's Avatar
Default Re: B20B/B18B Pistons...What should I use? (AutoFabProductions)
any vtec piston will be fine its just the valve reliefs that would have been the problem non vtec to vtec / but vtec to non vtec is fine
c speed racing .com?
Old Oct 13, 2004 | 05:30 AM
What i am wondering is what piston to use to obtain 11:1 compression since the b16 heads are different from the b18 heads. i dont think i can go by the compression they list for a b20/b16 crvetc setup.
Old Oct 13, 2004 | 03:54 PM
bump
Old Oct 13, 2004 | 06:38 PM
Combustion Contraption's Avatar
11:1 compression? call wiseco and specify youre setup. They should be able to give you some pistons tailored to your needs.
Old Oct 13, 2004 | 07:03 PM
DEVIOUS_EG*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoFabProductions &raquo;</TD></TR><TR><TD CLASS="quote">What i am wondering is what piston to use to obtain 11:1 compression since the b16 heads are different from the b18 heads. i dont think i can go by the compression they list for a b20/b16 crvetc setup. </TD></TR></TABLE>a 5.1cc piston dome will get you close to 11.1cr with your stock b20/LS head.. contact Jeff at IB..
Old Oct 13, 2004 | 08:02 PM
FATBOYeg6's Avatar
Default Re: B20B/B18B Pistons...What should I use? (DEVIOUS_EF*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">any vtec piston will be fine its just the valve reliefs that would have been the problem non vtec to vtec / but vtec to non vtec is fine
c speed racing .com?</TD></TR></TABLE>
maybe i am reading the original post wrong, but he says he is using a B20B block. b20b = 84mm, any vtec = 81mm. that means there are no vtec pistons that will work.
PphamEK
15
Sep 21, 2006 06:42 PM
b20integrapower
Jan 31, 2006 10:34 PM
hovic
Aug 17, 2005 07:42 PM
thatgsr
Feb 22, 2004 10:32 AM
. o 69 o .
Jan 24, 2002 07:37 PM
