Need part numbers
Old Oct 12, 2004 | 06:01 PM
hawkmgc's Avatar
Default Need part numbers
I have seen either here or another so I am going to post on both. Does anyone know the part numbers of the ball joints for a 1991 Honda Accord?
And if you say the upper front is control arm only then you are just as (#*&$@*#&(#*&%(#&$(&#$(*#&$(*&#$(&# as the parts store.
The upper ball joints can be changed just as the lowers. Same with the rear ball joints. But I need to find someone who has honestly done this to get the part numbers and manif. name of the ball joint.
Thanks
Old Oct 12, 2004 | 08:17 PM
SlammedCD7's Avatar
Default Re: Need part numbers (hawkmgc)
http://www.hondaautomotiveparts.com/ use that, has just about every part with exploded views of the part
Old Oct 13, 2004 | 05:55 AM
hawkmgc's Avatar
Default Re: Need part numbers (Wylie15)
that is a supper site that gives you a full break down of the parts, but does not give me what I need.
I know that the ball joints can be replaced on the control arms upper. I have done it before. But like a dummy I did not keep the part number of the ball joint used. Thanks though
Any one else?
Old Oct 13, 2004 | 07:13 AM
James's Avatar
Try Honda dealer/parts dept. and see what they say?
Old Oct 13, 2004 | 08:46 AM
jb.'s Avatar
jb.
call up the local dealer parts department and ask them, and make sure the ball joints can be changed, b/c on my 95 accord they cant so you have to replace the whole control arm. They should be able to tell you everything you need to know, and if that doesnt work try another dealer
Old Oct 13, 2004 | 06:20 PM
hondadude's Avatar
You didn't buy the ball joint alone from the dealer...you got it from a parts house.
Honda only sells the arms as a unit; but the parts houses will have the replacement joint that can be pressed in to the arm.
Old Oct 14, 2004 | 02:27 AM
Morthren's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wylie15 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondaautomotiveparts.com/ use that, has just about every part with exploded views of the part </TD></TR></TABLE>
This site is A++++++ I've always wanted to see the exploded view of parts online. This will save so much time instead of going to a dealer. Thanks!
Th3thirdwh33l
May 20, 2015 06:24 PM
gnx547
Jan 7, 2009 02:18 PM
715_guy
Oct 4, 2006 10:54 AM
vtecmw
Dec 31, 2005 07:28 AM
