please help header install problems.. HELP HELP!
ohk guys i need some help. i have 00 civic si. i have the new headers installed.. the car is loud as hell is this due to the lack of oxygen sensor. there is a hole for a 02 sensor but i cant get the old one out of the old manifold. i have a o2 remover and it just stripped the damn thing. i gueess ill spend 100 bones on a generic one.. any suggestions on brand. also the next problem i have is the fact that a bolt from the exhaust manifold broke off into the block.. its flush with the headers meaning if i take off the header there will be a quarter inch of bolt.. im thinking of taking off the header and trying to get that bolt out... please help you guys im in norfolk virginia if anyone is local and want to help me hit me up louie@brainlink.com. anyways my hands hurt im gonna continue working on it tomarrow.. the ***** at advanced gave me the wrong exhaust gasket also so i reused old one.. i guess ill try and find the right tommarro when i get the o2 sensor.. please you guys help me i need suggestions.. the car is soo loud..could that be just from the o2 hole?
sorry wrong forum but you accord guys should be able to help my car is a civic si.. i apologize again for the wrong forum
if you really cant get your old o2 sensor out, then just buy a new one, the noise is probably just from that....and you should be fine reusing your gasket if its still in good shape.....and about the stud breaking off, ive had that happen before and its a bitch!....just get someone to extract it for you if youre not a skilled bolt extractor!......and one more thing.....chillax!
As far as your o2 sensor I believe OEM uses ngk or bosch (not 100% sure which one
) but in all honesty oem would be the best way to go.
If you cannot get the o2 sensor out take it to a exhaust shop and they should be able to get it taken care of
) but in all honesty oem would be the best way to go. If you cannot get the o2 sensor out take it to a exhaust shop and they should be able to get it taken care of
Spray some PB Blaster around the o2 sensor, then let it sit overnight. Get a wrench on that in the morning and it should loosen up with a little bit of manpower. I had to do the exact same thing on my accord. Had to drive from my friend's house with the hole in the header.. it is NOT a pleasant noise.
all the loudness is from the hole in the header, its like a really big exhaust leak. but as far as gettin o2 sensors out, follow what "pyrojeff" said<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrojeff »</TD></TR><TR><TD CLASS="quote">Spray some PB Blaster around the o2 sensor, then let it sit overnight. Get a wrench on that in the morning and it should loosen up with a little bit of manpower. </TD></TR></TABLE>
superhatchbackbros
Jul 30, 2006 12:51 PM
Audio28
Feb 26, 2003 03:05 PM
