where do these connectors go...HELP!!!
Old Oct 12, 2004 | 04:58 PM
JDMlyfestyle's Avatar
Default where do these connectors go...HELP!!!
ok the ink rubbed off all of my connectors and i got all of them on cept the following five.
How can you tell the TPS and MAP sensor apart?
2 pin connectors they are round
#1 yellow w/ black stripe & black w/ blue stripe
#2 Red w/ blue stripe
#3 Green wire & Black wire.
2 pin Connectors
And this Connector is a Mystery connector.
3 pin Connector
red w/ yellow stripe
blue w/ red stripe
white w/ red stripe.
Modified by JDMlyfestyle at 6:11 PM 10/13/2004
Old Oct 12, 2004 | 06:11 PM
no one knows?
Old Oct 12, 2004 | 09:07 PM
Hockey27925's Avatar
Default Re: where do these connectors go...HELP!!! (JDMlyfestyle)
what motor are you running, it sounds lie ka gsr but here goes,
#1. Idle air control valve, its behind the intake manifold near the firewall u have to feel for it
#2 red w/ blue stripe - knock sensor goes under intake manifold into the block
#3green and black – power steering pressure switch behind the motor usually between block n firewall under IM
3 pin connector – I would have to know if its round or square, square looks like alternator
Old Oct 12, 2004 | 11:09 PM
GRAVEDIGGER's Avatar
Default Re: where do these connectors go...HELP!!! (Hockey27925)
pics??
Old Oct 13, 2004 | 02:11 PM
someone help me
Old Oct 13, 2004 | 02:23 PM
Im running a B16a2 in a EG with Chipped P28. My Dizzy plug is Blue.
Old Oct 13, 2004 | 03:18 PM
no one can help me?
Old Oct 13, 2004 | 05:09 PM
Default Re: (JDMlyfestyle)
Ohh Common there has to be someone that can help me. No one knows the answer to this ? But im sure alot of you can answer Dumb ?'s and ?'s that have been answered a million times?
Old Oct 13, 2004 | 05:15 PM
mjrage's Avatar
Hockey has them right.
I had a 3 pin dangling.
What codes are you throwing?
Old Oct 13, 2004 | 05:36 PM
i know for a fact that the map sensor isnt the sqaure one. the map sensor is identical to the TPS sensor. and there both larger round 3 pin connector.
Old Oct 13, 2004 | 08:34 PM
edo3276's Avatar
the square one might be the leftover plug from the egr in the old motor.. Are you using the stock harness?? is the round plug grouped together with an identical plug only with longer wires if it is, then the longer one is the MAP sensor and the shorter one is the TPS.
Old Oct 13, 2004 | 10:18 PM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
map and tps is simple plug them in if your car startes its fine if it doesnt switch umm. acutaly it will start but it will die when u give it some gas.
square one guild be crank angle sensor if your old motor had it.
Old Oct 14, 2004 | 08:38 PM
if that last plug is all the way on your driver side of the engine bay then im guessin this, its a crankshaft position center which plugs into a 96+motor behind the timiing belt cover next to the crank shaft pulley, now if you have a 95 and before model motor you have to do some major wiring from that clip to the dizzy, but i dont want to get into detail if its not true, basically all it means is that obd2 motors run off crankshaft postion sensor and obd1 motors run off camshaft postion sensor, which is why obd1 motors dont have the connector and that sensor is built into the dizzy so then u have to run the wires from the driver side of the bay to the dizzy and get an obd1 connector for the dizzy, pop out the wires and install new ones with the correct wire diagram for the obd1 motor. let me know if u need help, if not it could just be you alternator plug
Ef4doorwagon
Dec 29, 2014 03:08 AM
scatterbrain756
Dec 28, 2010 12:33 PM
bmbarnum
Nov 18, 2010 01:38 PM
accordguy2001
Jan 28, 2008 05:30 PM
Fuster_Cluck
Apr 22, 2003 08:56 PM
