axles for a B18b swap
Old Oct 12, 2004 | 01:35 PM
boi-alien's Avatar
Default axles for a B18b swap
My buddy wants to put in an LS/VTEC in his 1989 Civic, what kind of axles should he be using on either side? thanks in advance!
Old Oct 12, 2004 | 02:06 PM
dr_latino999's Avatar
Default Re: axles for a B18b swap (boi-alien)
Which transmission?
Old Oct 12, 2004 | 02:09 PM
JDMDC231's Avatar
Well if its not a si then he will need to swap out the hubs and get some si ones.... umm for the axles he will need the 90-93 integra axles basically the same on both sides.....
Old Oct 12, 2004 | 03:52 PM
boi-alien's Avatar
Default Re: axles for a B18b swap (JDMDC231)
i think he's using a B16a Y1? (not sure) tranny.
so basically as long as he has an Si, he can buy G2IC axles for both sides and he should be ok?
Old Oct 12, 2004 | 04:07 PM
LSvtechatch97's Avatar
G2IC is a website, Generation 2 Integra Club.
He can buy any B series axles he wants as long as they mate to the halfshaft and he has the SI hubs on it.
Old Oct 12, 2004 | 04:32 PM
Slopoke's Avatar
Default Re: axles for a B18b swap (FUKuPAYme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Which transmission?</TD></TR></TABLE>
Doesnt matter. All b series trannys accept the same axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC231 &raquo;</TD></TR><TR><TD CLASS="quote">Well if its not a si then he will need to swap out the hubs and get some si ones.</TD></TR></TABLE>
Nope. Only the HF and standard models require you to swap out hubs.
DX, LX, EX, and SI all have the same size whole in the hub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUKuPAYme &raquo;</TD></TR><TR><TD CLASS="quote">He can buy any B series axles he wants as long as they mate to the halfshaft.</TD></TR></TABLE>
Yep in other words, use '90-93 axles with a '90-93 half shaft and '94-up axles with '94-up half shaft. (B series, of course!)
You will have to remove the dust cover from the hub and the plastic ring on the outer joint of the axles.
or just get custom axles.
Old Oct 12, 2004 | 04:34 PM
kurinto's Avatar
Si or dx hubs work, on the hf you will need to change the hubs. That's for a crx, I dunno about a hatch with std and all that business.
Old Oct 12, 2004 | 04:39 PM
Default Re: axles for a B18b swap (kurinto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kurinto &raquo;</TD></TR><TR><TD CLASS="quote">Si or dx hubs work, on the hf you will need to change the hubs. That's for a crx, I dunno about a hatch with std and all that business.</TD></TR></TABLE>
well correct me if im wrong but B series axles don't fit DX hubs cuz i just did a b16 into a DX and it didn'tfit so we had to do SI hubs
Old Oct 12, 2004 | 04:45 PM
Slopoke's Avatar
I helped a friend do a b16 swap into his dx, axles went in fine.
Old Oct 12, 2004 | 05:44 PM
boi-alien's Avatar
ahh, alright thanks a lot... and sorry about the G2IC... i don't know what I was thinking of. So basically just pick up some 90-93 axles and the 90-93 half shaft and he'll be alright. He does have an Si.
Old Oct 12, 2004 | 08:57 PM
ya and make sure the halfshaft fits correctly on the block, 96midorihatch had a problem with his halfshaft not bolting into the block with his b20vtec setup.
Old Oct 12, 2004 | 09:45 PM
kurinto's Avatar
well correct me if im wrong but B series axles don't fit DX hubs cuz i just did a b16 into a DX and it didn'tfit so we had to do SI hubs</TD></TR></TABLE>
I used 91 teg axles in my 88 dx (auto) and they worked fine, perhaps there are different styles.
slo_ej8
Apr 8, 2008 04:35 AM
slowB20ej8
Jun 23, 2007 08:32 AM
rrrevs
Mar 27, 2006 05:18 PM
handa
Jun 14, 2005 09:00 PM
eghonda
Jun 5, 2004 08:04 PM
