obd2 distributor wiring to obd0 plugs
Hey, I have a p28 ecu , 88 crx hf , and a d16y8 distributor. Im trying to connect the obd2 distributor wires to the obd0 end of my plugs but the obd2 has 8 wires(tan, white with blue stripes,grey,white,blue,black with yellow stripe,tan with blue stripe,tan with green stripes).My obd0(9 wires total) end has black with yellow stripe,two white wires,white with blue stripe,tan with blue stripe,blue with yellow stripe,dark blue wire,tan wire,light blue wire. Can someone tell me the which wire goes to which since they got some differences. Thanks!
It all depends on the conversion harness your using.. The one that I built myself just matched color for color.. But if your not using a conversion harness then you can just put a obd2 dizzy on a obd0 car..
im cutting the dizzy plugs off so that i can get the wires then ima just wire them to the plugs i took off of my obd0 distributor.Thanks(i also bought the obd0-obd1 conversion harness from blown90hatch if that helps)
Modified by CRX_Control at 3:15 PM 10/12/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">im cutting the dizzy plugs off so that i can get the wires then ima just wire them to the plugs i took off of my obd0 distributor.Thanks(i also bought the obd0-obd1 conversion harness from blown90hatch if that helps)
Modified by CRX_Control at 3:15 PM 10/12/2004</TD></TR></TABLE>
Im not sure how his harnesses are setup.. Maybe he can chime in and let you know the correct way to do this..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">i dont see why i cant just cut the plug and wire it up to the obd0 dizzy plugs?
You can do that but its twice as much soldering. Get some obd 2 plugs and go from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control »</TD></TR><TR><TD CLASS="quote">sorry. twice as much soldering? How is this
I misread it. Sorry
</TD></TR></TABLE>I misread it. Sorry
Aight what they are tellin u to do is:
1. the grey plug, get the other part, that is on the engine harness, cut the wires long enough to solder and reattach to more wires.
2. Plug them up like you would do if you were installing the dizzy on the car.
3. Then once u find out which wires on the OBD 2 harness correspond with the OBD0 wires solder them together.
4. install Dizzy on car and plug up OBD0 male and female plugs.
There you have basically built a conversion harness.
PLEASE, IF I AM WRONG SOMEONE CORRECT ME.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89LScrx »</TD></TR><TR><TD CLASS="quote">Aight what they are tellin u to do is:
PLEASE, IF I AM WRONG SOMEONE CORRECT ME.</TD></TR></TABLE>
Yah i see what your saying, what i wanna do is forget about the conversion harness and do the wiring without it because im so broke and i cant afford it. even tho it might be like 50 cents.I just want to know which wires go to witch so i can wire it up without the harness plug part from an obd2 engine
Was this distributor purchased from Distributor king or somewhere other than the dealer? Many of those wires are non OEM color that do not match the ETM or Service manual. Try this and let me know.
OBd2-------------------Function--------------------------OBD0
Tan----------------------CYPP--------------------------Thin White
White/Blue--------------TDCM-------------------------White/Blue
Grey---------------------CYPM-------------------------Blue/Yellow
White--------------------CKPM-------------------------Tan
Blue---------------------CKPP--------------------------Blue
Black/Yellow------------IG Coil------------------------Black/Yellow
Tan/Blue----------------TDCP--------------------------Tan/Blue
Tan/Green***----------ICM----------------------------Fat White***
N/A----------------------RPM Tach----------------------Dark Blue
It is my feeling that most of your "TAN" wires are also commonly referred to as"PEACH" or "ORANGE" as well. Try this out and let me know. On the OBD2 distributors, the tach wire is not present from there. You can tee the dark blue wire into the yel/green wire.
*** On this one, I believe that you "TAN" wire here is rather Yellow in color just dirty maybe?
Jason
Jason
jasons cool if you gat your ecu harness from him then the instructions should say about which white to what, I just did an obd0-1 conversion with a 00' gsr dizzy and his harness. he is a stand up guy and will help out, try what he says he knows his stuff.
You can do this..
You can do this..
Ok, Would anyone know what the P and M mean after (CKPM or CKPP)?
And for the Obd-0 side does anyone know which sensor are P and M??
Obd-0 to Obd-2
orange--lite blue Crank Sensor Input----Crankshaft Position Sensor P (CKPP)
orange/blue--orange/blue TDC sensor Input---TDCP
blue/green--orange CYL sensor input---Cylinder Position P (CYPP)
white--yellow/green ICM---ICM
white/blue--white/blue TDC Sensor Input--TDCM
blue/yellow--blue/yellow CYL Sensor Input-- Cylinder Position M (CYPM)
white--white Crank Sensor Input---Crankshaft Position M (CKPM)
*Note: orange is refer as peach
Obd-0 to Obd-2
The wire write up blownhatch gave me didnt work , but i emailed him back, hopefully he will post here or write me back on what to do
The problem is that you do not have OEM colors on all the wires. Therefore, the only real way for me to tell is to open the distributor and trace where each wire goes. If you want to open it up and take some pics, let me know. I am replying back to your email asap.
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH »</TD></TR><TR><TD CLASS="quote">The problem is that you do not have OEM colors on all the wires. Therefore, the only real way for me to tell is to open the distributor and trace where each wire goes. If you want to open it up and take some pics, let me know. I am replying back to your email asap.
Jason</TD></TR></TABLE>
i didnt wanna open it the whole way hopefully this may help.i got the black/yellow going to black yeloow, and the green/yellow going into the Blue wire on the obd0 side.
in that picture its the tan(orange) and grey wire i was talking about, i dont have thos wired up as of now and im waiting for your post .so far this is what i got
obd0---------------obd2
blk/yellow---------blk/yellow
Blue----------------Yellow/green
orange/blue-------orange/blue
white/blue---------white/blue
and these are the ones i got unwired
obd0(unwired)-white(by self),white(next to two wires),blue/green,blue/yellow,orange.
obd2 dizzy(unpluged)-grey,white,light blue,orange.
Any help is fine , thanks very much!
