CRX Fuel/ignition problem
Old Oct 12, 2004 | 09:46 AM
d16y8crx's Avatar
Default CRX Fuel/ignition problem
so i got a d16y8 swap in my 89 crx hf, i've had this swap for almost a year now. when i first had it done, i was running an Hf dizzy and a pg7 ecu, with obd0 integra injectors. i was getting about 27 mpg, and the air fuel was stable. recently, i had a problem with my o2, it was running rather rich for about a month. i fixed that, now i got an Si dizzy with a chipped pm6 ecu, but now its tweaking out. i have a huge power loss in lower rpm (up to about 3000 rpm), im getting about 20mpg, and my air fuel is tweaked, its going from the first rich/last stoich mark, then jumps alll the way down to the bottom lean, and bounces back and forth, also, its all the way in the lean when i first start off, then kicks over to stoich/rich at about 2000rpm. guys at axiom said it was timing, that the dizzy was completey wrong and its ******* everything up, but why was it runnign right with the hf one then?? sorry this post is so long, but i figured it would be better to get all the info out.
Old Oct 12, 2004 | 10:21 AM
crx_88_si's Avatar
are you getting any CEL's ?
Old Oct 12, 2004 | 10:55 AM
d16y8crx's Avatar
Default Re: (crx_88_si)
no, i was getting the o2 one a month ago, but i fixed that, now theres nothing
Old Oct 12, 2004 | 11:33 AM
dr_latino999's Avatar
Default Re: (d16y8crx)
Hmm...What is the PG7 ecu out of? Early Teg?
Old Oct 12, 2004 | 12:10 PM
d16y8crx's Avatar
Default Re: (dr_latino999)
i think it was 87, but im not sure.
nolimit0025
Jul 11, 2008 03:47 PM
cavakilla
Mar 22, 2004 05:59 PM
CRX A4
13
Feb 7, 2003 06:01 PM
90TegRex
Jun 11, 2002 07:53 PM
