Stainless Steel Turning Dark Purple
Old Oct 12, 2004 | 08:08 AM
Ri5e's Avatar
Default Stainless Steel Turning Dark Purple
Is there any way to prevent Polished Stainless Steel turbo manifolds from turning DARK PURPLE?
I'm about to my new turbo manifold on and I would like to keep my mainfold a "Gold/Bronze" color. My friend has a polished stainless steel inline pro manifold and it looked nice at first but now it has turned very dark purple.
Old Oct 12, 2004 | 08:22 AM
Doctor CorteZ's Avatar
Default Re: Stainless Steel Turning Dark Purple (TurboSmart)
its from heat.
the way to stop it from turning color is never install it.
Old Oct 12, 2004 | 10:33 AM
Ri5e's Avatar
Default Re: Stainless Steel Turning Dark Purple (Doctor CorteZ)
Because I've seen some people's setup (Hytech Manifold) and it seems as though their manifolds are always "Gold" in color.
Old Oct 12, 2004 | 12:05 PM
Finest's Avatar
Wipe off any and all oil residue after you've installed it. Usually, if using your hands, the oil from your hands itself can make it turn an ugly color. Wipe it CLEAN before starting the car. Some say even wipe a coat of WD40 on it to get it a golden color. But I haven't tried that, so just keep it clean.
Old Oct 12, 2004 | 08:14 PM
Magnaflow's Avatar
Default Re: Stainless Steel Turning Dark Purple (Finest)
The hotter it gets the more purple it will go nothing you can do about it really. Why dont you get it coated?
Old Oct 13, 2004 | 07:40 AM
Ekasey's Avatar
Default Re: Stainless Steel Turning Dark Purple (Magnaflow)
Clean with brake clean before
Old Oct 13, 2004 | 01:10 PM
h22 civic's Avatar
Default Re: Stainless Steel Turning Dark Purple (eLusive ek4)
jet hot coat it wd40 works
Old Oct 13, 2004 | 02:59 PM
Bailhatch's Avatar
Default Re: Stainless Steel Turning Dark Purple (h22 civic)
If you like the raw stainless outside, you can use a ceramic coating on the inside to prevent blueing. They do it on hot rods and whatnot.
Old Oct 13, 2004 | 04:26 PM
asterix_2ksi's Avatar
New User
Properautocare.com sells stainless and chrome metal cleaner under the motorcycle section... they claim it removed the blue color off of an exhaust pipe and restored the chrome finish without scratching.
Old Oct 14, 2004 | 06:16 AM
Sobe_Death's Avatar
yeah, if you jet hot coat it, it wont turn the blue color.
Old Oct 14, 2004 | 05:04 PM
Ri5e's Avatar
Default Re: (Sobe_Death)
Is jet hot coat a CLEAR coat?
Old Oct 14, 2004 | 07:25 PM
matt_sb2000's Avatar
Default Re: (TurboSmart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart &raquo;</TD></TR><TR><TD CLASS="quote">Is jet hot coat a CLEAR coat? </TD></TR></TABLE>
It's a ceramic coating. It could be clear...
http://www.carcraft.com/techarticles/80038/
Article.
Old Oct 14, 2004 | 08:01 PM
Bailhatch's Avatar
Default Re: (matt_sb2000)
all you need is the correct coating on the INSIDE of the runners. it's been done before.
Old Oct 16, 2004 | 04:39 AM
Sobe_Death's Avatar
the jet hot ceramic coat looks exactly like polished stainless...
forceinducted
May 12, 2012 11:10 PM
ASpecProducts
22
Dec 6, 2010 10:49 AM
95BoostedEJ1
Jun 28, 2010 08:24 PM
hood ride eg
Paint and Body
May 20, 2010 04:19 PM
vtec-adykt
Apr 29, 2009 07:59 PM
