gear ratio?
ok i remember a while back that someone on here posted about a
Gear Ratio Calculator i think it was off SCC but im not sure and im looking for it.
Can someone please give me a link? Also i think it should be in one of those sticky on top of this forum. thanks guys
while im here would a b16 FD work with a GSR gear set? if i had that calcuator i wouldnt ask. thanks again
Do a search. Last time I was looking for it, I found it with "gear calculator", archived, all forums. Second one I clicked on.
And why were you wondering if a B16 FD would fit a GSR? Is your GSR one broken? If you want to swap it because you are under the impression it is a different ratio, the GSR is 4.40 just like the B16's. Also the gear calculator doesn't tell you what parts fit what. They just have predetermined figures plugged in which are easily changed.
carlos8
Nov 30, 2011 11:52 AM
