2000 ek hatch tokicos fit a95 delsol?
Old Oct 11, 2004 | 09:01 PM
one slow eg5's Avatar
Default 2000 ek hatch tokicos fit a95 delsol?
Old Oct 11, 2004 | 09:15 PM
jerbear!'s Avatar
Default Re: 2000 ek hatch tokicos fit a95 delsol? (one slow eg2)
yes im almost positive they will.
Old Oct 11, 2004 | 09:20 PM
rome's Avatar
fit perfect...
Old Oct 12, 2004 | 08:04 AM
xkwzt21's Avatar
Default Re:
yep should even have the brake line mounts on it
Old Oct 12, 2004 | 05:59 PM
Default Re: Re: (xkwzt21)
THANKS
Old Oct 12, 2004 | 07:30 PM
BlueIntegraBoy's Avatar
Tokicos fit 92-00. Only difference is the the brake lines. Brake lines mount at the bottom of the struts for 92-95 (93-97 sols) and on 96-00 it mounts elsewhere.
Old Oct 12, 2004 | 09:25 PM
Default Re: 2000 ek hatch tokicos fit a95 delsol? (BlueIntegraBoy)
thanks
Old Oct 12, 2004 | 09:33 PM
fishnfst's Avatar
Some companies make two different rears. They make a 92-95 and a 96-00 the only difference being the width of the fork on the bottom. The 92-95's are wider than the 96-00. Tokico only makes one kind of rears for both generations. If you have a 96-00 you would put in the supplied spacers. For your sol they should bolt right up. Tokico only makes one front for all 92-00 civics.
Old Oct 13, 2004 | 12:28 PM
Default Re: (fishnfst)
thanks again...
Old Oct 13, 2004 | 12:34 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">Some companies make two different rears. They make a 92-95 and a 96-00 the only difference being the width of the fork on the bottom. The 92-95's are wider than the 96-00. Tokico only makes one kind of rears for both generations. If you have a 96-00 you would put in the supplied spacers. For your sol they should bolt right up. Tokico only makes one front for all 92-00 civics. </TD></TR></TABLE>
Bingo.
96-00 Civics have a more narrow rear lower control arm bushing and lower strut fork, so using 92-95 suspension on the 96-00 will require using washers at the bottom strut forks.
I run 96-00 Konis on my 92-95 Civic, and since my lower control arm busings were fatter I had to shave them to fit the more narrow EK struts.
Also 96-00 Civic front struts have no mounts for the brake lines, 92-95 do.
ilovemydc4
Nov 20, 2007 11:26 AM
B16B_coupe
Suspension & Brakes
Aug 22, 2006 04:33 PM
1POINT8VTEC
Jan 24, 2006 12:06 PM
Shongku
Aug 5, 2004 09:14 PM
MarkZeroNine
Nov 2, 2003 08:24 AM
