stupid question about skunk2 manifold..
Old Dec 16, 2001 | 09:01 AM
CoLJeW's Avatar
Default stupid question about skunk2 manifold..
ok I got a dumb question.. is the IAB the sensor on the top of my GSR throtle body? If so what do I wire it to.. I am putting my b18c in my EF.. i got the skunk2 manifold to make things easier. what are the extra thin gs I need to wire same as a b16? knocksensor, oil pressure switch, 2nd O2, vtec solinoid, whatelse? where the hell does the IAB go to??
[Modified by CoLJeW, 6:01 PM 12/16/2001]
Old Dec 16, 2001 | 10:17 AM
CoLJeW's Avatar
Default Re: stupid question about skunk2 manifold.. (CoLJeW)
nevermind that first question I think my head found itself in my *** for a second..was thinking the IAB was something else.. but now since my head has been removed I realized that it is what runs the butterfly plates.. I think the sensor on the top of the GSR throtle body is the MAP sensor.. anyone??
Old Dec 16, 2001 | 10:23 AM
Blown90hatcH's Avatar
Yes, the sensor that is on top of the GSR TB is the Map sensor. ON the EF it is mounted on the firewall. You will proll have to extend the wires to make that plug reach the gsr map sensor.
Old Dec 16, 2001 | 12:31 PM
CoLJeW's Avatar
Default Re: stupid question about skunk2 manifold.. (Blown90hatcH)
ok so I got that taken care of.. on to the evap purge control... should I use the stock one on the firewall or I was thinking while I was at it I could get ride of all that junk on the firewall and run the little purge control off the GSR manifold, just rewire that to the stock plug.. will it work ok..
sirtef9
Jun 17, 2014 05:15 PM
noface
Feb 21, 2013 09:01 AM
SVOHK
22
Apr 2, 2010 05:40 PM
airwalk07143
Mar 18, 2006 05:55 PM
SiR HatchAlot
Jan 11, 2004 08:50 PM
