Ground Control Sleeves and Koni Yellow dampers.
I have a GC spring setup on some Tockico illumina dampers. and i planning on getting some Konis revalved on January. Do i have to get new sleeves too? or can i run the knois with the pearch that a standard spring would use.
Just like i kind of have now but with a koni diameter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPiFF »</TD></TR><TR><TD CLASS="quote">Search.
Or..........
Or..........
The Konis will be a 42mm OD body and the sleeves need to fit the body properly and have a provision to capture and cover the spring perch circlip in the body. Both Koni and Ground Control make sleeve systems to propely fit. Call Ground Control to see if your sleeves can be made to fit properly. Properly capturing and retaining teh cirlip is the key to keeping everything strong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee »</TD></TR><TR><TD CLASS="quote">Call Ground Control to see if your sleeves can be made to fit properly. .</TD></TR></TABLE>
530-677-8600
530-677-8600
