Question about MC problem
Old Oct 11, 2004 | 05:49 PM
LoooseGSR's Avatar
Default Question about MC problem
Okay, so I'm doing a MC swap to a 15/16ths on my CRX Si(89).
Kinda bench bled, but it was making a mess...so I just put it in(I figured it would be ok because I was flushing the whole system anyway.)
Once I got it on, I proceeded to flush the whole system, pedal was much firmer, and when I went for a test drive, I pulled to like 6k in 2nd then slammed on the brakes, they grabbed hard at first, then sank to the floor and I lost brakes.
I also noticed that fluid was leaking from where the MC meets the booster.
I figured this was bad, so I stopped driving it...what could have caused this is my question...I forgot to replace the little gasket that goes between the MC and Booster when I put the MC on, so could that be it? Or is the MC bad? I used a speed bleeder to get the air out, let it run for a good 15-20 minutes on each wheel.
Please someone shed some light, I have a track event this weekend and I need to get this done.
Old Oct 11, 2004 | 06:04 PM
CRX Toad's Avatar
Default Re: Question about MC problem (PSUCRX)
Hey man when I did that swap just put the gasket in and it should be fine...if not get call Brian...he talked me through it over the phone some 2000 miles away. I think the MC will fine J.
Old Oct 11, 2004 | 06:26 PM
LoooseGSR's Avatar
Default Re: Question about MC problem (CRX Toad)
Yeah I thought that might be it...I'm supposed to pick up a different MC tonight...but I'm going to try the other thing first...if it still feels like crap...well then it's the MC
94lspower
May 19, 2007 08:42 PM
AznPrideYo
Aug 26, 2006 12:00 PM
BluntMan
Jan 14, 2004 10:56 AM
JackAcc
Sep 16, 2003 07:18 PM
