Catch can: What hoses won't collapse?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR »</TD></TR><TR><TD CLASS="quote">regular fuel hoses
agreed. the crappy nylon reinforced hoses that came with mine collapsed once they got warm... ditched them immediatly for regular fuel hosing. Fuel hosing is build to withstand positive internal pressure, but is also great for negative internal pressure.
</TD></TR></TABLE>agreed. the crappy nylon reinforced hoses that came with mine collapsed once they got warm... ditched them immediatly for regular fuel hosing. Fuel hosing is build to withstand positive internal pressure, but is also great for negative internal pressure.
dennis
ive been running the endyne style breather kit w/ the nylon hoses for ever, and no problems what so ever, and so have a numerous other people i know.
a plumbing supply near work.
I believe we have some left over if you want i can check.
any home depot will have it, its pretty inexpensive.
I bought some regular 3/8s fuel hose today. I compared it to the bridgestone fuel hose that came with the catch can and the bridgestone is definately more quality. Much more dense with more of the threads(?) inside.
Just got back from the track last weekend and the hoses collapsed!
Anyone have any suggestions for heavy duty ones? The ones I ran were regular fuel line hoses.
Could it be the location? I have it sitting pretty far away right next to the driver side headlight where the windshield washer resevoir used to be.
how the ****?
well you could try coolant lines
they have more threads in them
are you routing them that they touch a heat source?
i can't understand how you collapsed rubber fuel hose lines
The fuel lines got really mushy and soft and as soon as I moved them, they curled up on me.
They really aren't touching anything HOT. I'll take a pic of it when I have time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">how do you have your setup routed?
PVC->catch can->manifold ?</TD></TR></TABLE>
Exactly.
I also filled it completely up this weekend.
1st and 2nd sessions it did not catch anything.
3rd session = half full
4th session = full, almost maxed out
I drained it immediately after the 4th session. On the trip home, not one drop.
Exactly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cod Sac »</TD></TR><TR><TD CLASS="quote">Maybe your PCV valve is stuck closed? </TD></TR></TABLE>
How can I test?
How can I test?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">
Exactly.
I drained it immediately after the 4th session. On the trip home, not one drop. </TD></TR></TABLE>
Maybe your oil temps got too high during the 3rd 4th sessions.
i was chatting with some people who race alot of high out B series motor's and say its very normal for them to use oil, or catch can's to fill up quickly, nature of the best i guess
Exactly.
How can I test? </TD></TR></TABLE>
take it out, and shake it, it should rattle
one thing you can do, its ghetto, but it works pretty good
is clean in out with brake cleaner, just make sure to dry it out good before reinstallation
You can blow on it. It shouldn't let you blow. Then suck on it. It should open up. You should be able to do it with a hose attached. Oh and don't do it while the engine is running.
3rd and 4th sessions were definately hotter as the outside temps did increase and I was pushing the car a lot harder.
No oil was burned during the session.
How does heat relate to the catch can accumulating more oil? Isn't it really all based on vacuum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR »</TD></TR><TR><TD CLASS="quote">viscosity will change with temperature
my guess is that a thinner oil is easier to suck into the can</TD></TR></TABLE>
That logic works for me. Thanks.
yep, try runing an oil with a higher temp rating, RJ. i think was running 50 or something like that
