Honda S2000 Honda S2000
problems with aftermarket NSX exhaust
Old Dec 16, 2001 | 03:53 AM
cojones's Avatar
New User
Default problems with aftermarket NSX exhaust
Cross-posting this for a friend (non Honda-Tech member) who is had some significant problems with an aftermarket NSX exhaust from B&B Triflo
I hope B&B will stand behind their product
Whilst cleaning up after a DriverEd event at Sebring today, I noticed that the exhaust had generated a LOT of heat on the right side, enough to cause some damage:
- melting of the foam toolbox (and destroying several tools including the compressor)
- melting of part of the lower valance
Finally got the exhaust removed
- two large HOLES at the top surface, right side of the exhaust. Larger hole approx 3.5" x 3.75"; smaller hole approx 2" x 3". Holes joined by a crosswise crack approx 2.5" long
- upper seam (weld) on right side had cracked open -- approx 6.5" of seam was open
I believe the 2 holes were responsible for frying my trunk (deformed the external heat shield, melted down my toolkit, etc). I suspect the side crack/leak was responsible for melting my lower valance.
New pix uploaded to http://public.fotki.com/nsx1164/nsx_exhaust/
See more discussion on NSX Prime Forums -> http://www.nsxprime.com/ubb/Forum13/HTML/000145.html
Old Dec 20, 2001 | 02:47 PM
Etylorcen's Avatar
Default Re: problems with aftermarket NSX exhaust (cojones)
That that look terrible. I hope they do stand by their product. How much did the exhaust run for?
ohemgiii
Oct 2, 2015 08:38 PM
Acidcrakker
Sep 18, 2007 08:15 PM
acidburn2k2
Jan 7, 2006 01:03 PM
