Seperating front UCA ball joint
Old Oct 11, 2004 | 03:32 PM
revolt_allmotor's Avatar
Default Seperating front UCA ball joint
ok I'm trying to install an omnipower front camber kit (it replaces the front uca) on my eg. I removed the castle nut on the ball joint stud and pulled and hit the UCA with a hammer a few times and generally fucked with it but it wouldn't seperate.
so i'm guessing i need a ball joint seperator. i guess i'm gonna go to pep boys and rent the set. my question is: when i have the ball joint seperator do I just wedge it in there and wiggle it around or what?
the omni uca has a new ball joint in it so im not too concerned about damaging the original one..
Old Oct 11, 2004 | 03:48 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Seperating front UCA ball joint (909edge)
if you go to pep boys you could try using a fork. it's around $10 and that should work
Old Oct 11, 2004 | 04:00 PM
97civicdx's Avatar
A few times? If your car is a 92, you have to keep hitting it for a while, you really need to "shock" the ball joint loose if there is a lot of corrosion on there. My 97 didnt need that many whacks.
Old Oct 11, 2004 | 04:20 PM
civic-si-2000's Avatar
Default Re: Seperating front UCA ball joint (97civicdx)
I do these at work all the time. Get a steel headed hammer and knock the hell out of it. when that doesn't work get pissed off and hit it harder. It'll come loose.
esean93
22
Dec 23, 2008 02:37 PM
russianswty
Feb 18, 2007 02:24 PM
teler86
Dec 31, 2005 06:11 AM
