engine rebuild zc
Old Oct 11, 2004 | 03:10 PM
chwy_thoj's Avatar
Default engine rebuild zc
help fast, I need to know what is needed to rebuild a ZC from the bottom up. from what i've been reading... it looks like i need a civic 1.6 (bottom end) gasket kit and a teg head gasket kit. is this correct... what other information is needed.. what torque specifications should i follow??? please help fast... thanks, no flames please.. i've tried looking.. but need answers fast..
Old Oct 11, 2004 | 03:16 PM
chwy_thoj's Avatar
bump.. does anyone know the answer to this?
Old Oct 11, 2004 | 03:31 PM
mrspeaker's Avatar
Default Re: (chwy_thoj)
Dizzy--88-89 integra
timing belt--88 prelude2.0 si
Throttle body--88-91 civic/crx si
head gasket--89 integra
intake gasket--89 integra
exhaust gasket--89 integra
water pump--89-91civic/crx
oil pan gasket--88-91 civic/crx or 89 integra
oil filter--89 integra
spark plug wires--89 integra
spark plugs--88-91 civic/crx or 89 integra
Rod bearings--88-89 integra
Main bearings--88-89 integra
pistons--88-89 integra
Gaskets--Top half uses the 89 integra set
Gaskets--Bottom half uses d16a6 (dont know what else works)..
What else is there to replace??
Old Oct 11, 2004 | 03:34 PM
chwy_thoj's Avatar
thanks.. bump.. would it be a better idea to just buy a new one from hmotorsonline.com??? than a rebuild?? how much does it generally cost to rebuild from bottom/up?
Old Oct 11, 2004 | 04:08 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chwy_thoj &raquo;</TD></TR><TR><TD CLASS="quote">thanks.. bump.. would it be a better idea to just buy a new one from hmotorsonline.com??? than a rebuild?? how much does it generally cost to rebuild from bottom/up?</TD></TR></TABLE>
There is no such thing as a NEW one so it the rebuild would be worth it. Bottom up rebuild, $500 on up, depending on what type of deals you get on parts - don't skip out, go oem - and on labor if your block needs work.
jdm inc
Jan 8, 2010 01:12 PM
jdm inc
Jan 7, 2010 11:12 AM
jdm inc
Suspension & Brakes
Jan 6, 2010 11:31 AM
Frenshawas
Apr 20, 2008 05:48 AM
gregv
10
Feb 20, 2003 09:49 PM
