Need input, buying tomorrow
Old Oct 11, 2004 | 03:02 PM
Boosted2K's Avatar
Default Need input, buying tomorrow
I just found a virgin GSR block, and its just down the street, go figure.
What should I look for
1.I know to check the sleeves for cracks and scratches
2.should I check the deck height??
3.am I missing anything??
4.also what should I look for on the crank??
I'm not sure if it will be sleeved or not, thats still to be decided
I just don't wanna get screwed
Old Oct 11, 2004 | 04:27 PM
PrettyLude's Avatar
you can check the deck height, unless you have a precision machined straight edge, check for cracks in the sleeves, check and see if you see anything scarring on the crank and bearings
Old Oct 11, 2004 | 04:35 PM
eddyboy's Avatar
Default Re: (PrettyLude)
Make sure you get the main caps for the block if you do decide to buy it. Also I don't know how you can check this but, try to see if any of threads are stripped for the main cap and head studs.
GL
thecruzs2007@yahoo.com
Jul 24, 2010 10:55 AM
polyhonda
Mar 5, 2010 08:59 AM
EkFG
Jun 12, 2008 08:03 PM
SixguN
May 14, 2005 05:12 PM
