04 accords navigation system dvd rom
Old Oct 11, 2004 | 02:53 PM
dmonybagz's Avatar
Default 04 accords navigation system dvd rom
does anybody know how to get a dvd movie to play on the cars dvd rom
Old Oct 11, 2004 | 03:10 PM
pnut's Avatar
Default Re: 04 accords navigation system dvd rom (dmonybagz)
If you're having troubles with your DVD system I would recommend bringing it to your local Honda dealer to have them look at it and make sure it is nothing serious.
Old Oct 11, 2004 | 05:04 PM
dmonybagz's Avatar
Default Re: 04 accords navigation system dvd rom (pnut)
no,i have a navigation system that runs off a dvd rom in the trunk and i'm wondering if there would be some way around getting movies to play on it. to me it it seems that i probably have to burn the dvd off the computer,but what format i don't know but if you know some way then that would be great
Old Oct 15, 2004 | 05:21 PM
Qfactor's Avatar
navigation systems do not play DVD Movies, where did you hear this from.
Old Oct 18, 2004 | 05:45 AM
dmonybagz's Avatar
Default Re: 04 accords navigation system dvd rom (Qfactor)
if u don't know how to do it why even hit me up they run off a dvd rom how can they not
Old Oct 18, 2004 | 06:43 AM
Camelflaj's Avatar
I have an 03 accord with Navi. There is a way to play DVDs using a wiring kit.
Check out this thread: http://www.v6performance.net/f...t=dvd
And check out this link: http://www.avelectronic.com/products.htm
Old Oct 19, 2004 | 08:29 PM
Qfactor's Avatar
Default Re: 04 accords navigation system dvd rom (Camelflaj)
well actually what they are using is the Navigation screen as a monitor, but you have to buy their adapter/converter to switch video composite(rca) to RGB (component) since the Navi. screen uses the RGB signal. so if you if wanted to watch a movie you will still have to get a dvd-player and buy a signal converter. such as this one:
http://www.converters.tv/produ....html
and use your own video switch box instead of the infrared remote that they supply, this switch boxes can be bought at Circuit city, Radio Shack etc and the push-lock buttons can be mounted and labeled for your specific component, such as PS2,TV tuner,dvd player. you can even use the screen as a computer monitor since they use the same RGB signal...
mikein21061
15
Nov 2, 2015 06:26 AM
RJOker1227
Audio / Security / Video
Aug 7, 2003 09:05 PM
