Conversion harness???????
Old Oct 11, 2004 | 01:34 PM
jdmb18c's Avatar
Default Conversion harness???????
I know there is an OBD2 to OBD1 conversion but is there a 1 to 2 harness. I want to sell my hondata now that I am putting my JDM b18cR back to stock. (selling my toda B's) I have a 95 integra and the motor is a 99. If there is not a harness for my aplacation then what are my options and what works best?
Thanks.
Old Oct 11, 2004 | 01:49 PM
Blown90hatcH's Avatar
Default Re: Conversion harness??????? (jdmb18c)
I can build you a conversion harness from your OBD1 chassis to run that OBD2a conversion harness. Let me know.
Jason
Old Oct 11, 2004 | 04:09 PM
hondaguyef's Avatar
Default Re: Conversion harness??????? (Blown90hatcH)
Trust this Man^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Oct 12, 2004 | 02:23 PM
jdmb18c's Avatar
Will I have to convert the wiring on the motor back to 2 or can I just plug your harness into my car harness and then into a p73?
Old Oct 12, 2004 | 06:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmb18c &raquo;</TD></TR><TR><TD CLASS="quote">Will I have to convert the wiring on the motor back to 2 or can I just plug your harness into my car harness and then into a p73?</TD></TR></TABLE>
You will not need to convert anything on the chassis as long as the chassis matches the engine/ecu setup (vtec model wiring, etc.).
Jason
Old Oct 13, 2004 | 02:21 AM
jdmb18c's Avatar
Well my friend did the wire job on my car and as of the last 3 years I have been running the handata on a p72 and now on a p28. So this should work, right. Have you done a harness like this before? Because no one I have spoken with had ever seen it done before.
Old Oct 13, 2004 | 05:24 AM
OBd0 chassis to OBD2, OBD1 chassis to OBD2, OBD2 chassis to OBD0, etc. Hit me up when you are ready.
Jason
http://www.JKobdconversionharness.com
Old Oct 13, 2004 | 12:47 PM
PrettyLude's Avatar
how much your harnesses usually cost?
invisible
Nov 19, 2006 09:23 AM
accordmandan
Nov 10, 2005 10:03 PM
B20-Rex
11
Dec 17, 2004 08:37 AM
96Hatch
Nov 11, 2002 02:39 AM
