cracked something
Old Oct 11, 2004 | 12:37 PM
br'Y'an's Avatar
Default cracked something
what other fluids then antifreeze in your motor are green becuase i crack something but not by the radiator its behind the side of the passenger wheel that were it leaking from.
Old Oct 11, 2004 | 01:25 PM
JimBlake's Avatar
Default Re: cracked something (beatjunkie42)
Smell it. If it IS antifreeze then maybe it was a heater hose, or heater valve??
Old Oct 11, 2004 | 01:28 PM
br'Y'an's Avatar
Default Re: cracked something (JimBlake)
is it ok too drive it like that for about 40 miles because in at work and do you know if i did brake how much does it cost for a heater hose or the heater valve
Old Oct 11, 2004 | 01:34 PM
JimBlake's Avatar
I don't know what it costs, but if it IS the heater hose or valve, be careful. If it finishes breaking off altogether, it'll only take a minute to pump all your coolant out on the ground. Then you'll really be in trouble.
If it's seeping out from a loose hose clamp, maybe you'll be OK. If something's actually cracked, it's gonna only get worse. If you're not lucky, it'll get a lot worse real quickly.
Old Oct 11, 2004 | 01:39 PM
br'Y'an's Avatar
where the heater valve at
Modified by beatjunkie42 at 2:49 PM 10/11/2004
Old Oct 12, 2004 | 03:41 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beatjunkie42 &raquo;</TD></TR><TR><TD CLASS="quote">where the heater valve at</TD></TR></TABLE>What kind of car you got?
Usually, it's on a heater hose, right outside of the firewall. Maybe mid-height, closer to the passenger side. It's not very big, just a blocky thing in the hose with a cable attached to a lever that opens & closes the valve.
Old Oct 12, 2004 | 10:46 AM
br'Y'an's Avatar
the green liquid is coming from behind the passenger wheel by the arms
andyz
Apr 6, 2022 08:14 PM
victor.m
Aug 6, 2008 03:26 PM
b18c4door
10
Oct 19, 2007 06:22 PM
n0rmaL
Dec 1, 2006 04:40 PM
Black Paper Diary
May 29, 2006 05:32 PM
