dx head on hf
Old Oct 11, 2004 | 12:21 PM
vinniescrx's Avatar
Default dx head on hf
can i put a 16 valve head on my 8 valve hf crx
Old Oct 11, 2004 | 12:47 PM
eumoria's Avatar
Default Re: dx head on hf (vinniescrx)
::brain explodes::
Old Oct 11, 2004 | 12:57 PM
mrspeaker's Avatar
Default Re: dx head on hf (eumoria)
EDIT..
Hatchback al corrected me..
Modified by Mrspeaker at 5:44 PM 10/11/2004
Old Oct 11, 2004 | 01:00 PM
hatchback_al's Avatar
Default Re: dx head on hf (Mrspeaker)
no, the above statement is not true. The pistions in the HF block only have valve reliefs for 8 valves, not 16. Meaning that the first time u crank over your newly built motor, half your valves will bend just like that. Just put the whole dx motor in and use your old hf distributor, swap the DX intake to mpfi, get a pm6 ecu, and you will have an Si motor.
Old Oct 11, 2004 | 01:13 PM
mrspeaker's Avatar
Default Re: dx head on hf (hatchback_al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al &raquo;</TD></TR><TR><TD CLASS="quote">no, the above statement is not true. The pistions in the HF block only have valve reliefs for 8 valves, not 16. Meaning that the first time u crank over your newly built motor, half your valves will bend just like that. Just put the whole dx motor in and use your old hf distributor, swap the DX intake to mpfi, get a pm6 ecu, and you will have an Si motor.</TD></TR></TABLE>
the a6 is 1.6L and has a different cam...
Old Oct 11, 2004 | 01:42 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
the a6 is 1.6L and has a different cam...</TD></TR></TABLE>
And does not have intake runners and a thottle body that would choke on a straw
And doesn't have a 5500 RPM redline
Old Oct 11, 2004 | 02:07 PM
The DX Rex's Avatar
Default Re: dx head on hf (dr_latino999)
just buy a b18c5, that shud give u the performance your wanting, lol
Old Oct 11, 2004 | 05:45 PM
Default Re: dx head on hf (nyhustla2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">
And doesn't have a 5500 RPM redline </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah I know the a6 is a different cam, but not too different. If you have the DX head on hand its not worth pitching out the cash for an a6 head. And what I meant before by swapping to mpfi was to put on an a6 intake manifold. Sorry for being unclear on my part.
dod
Mar 20, 2006 08:15 PM
SloCrxDx91
Apr 21, 2005 12:45 PM
poweredbydvot
Feb 2, 2005 01:14 PM
5litereater
Jun 24, 2004 06:01 PM
GSRSNATCH
Apr 16, 2003 07:38 PM
