help! my civic wont start!
Old Oct 11, 2004 | 12:05 PM
29greencivic's Avatar
Default help! my civic wont start!
i drove my car to a carshow last week and it has been sitting for about a week in my garage and i went out to start it and nothing happend... "ok its the battery". so i hook up jumper cables and stuff and i know it has enough electricty becuse the hazzard lights work perfect but when the key is in the ignition there is no cluster lights, no headlights, no interior lights. im stumped. please help me! and i KNOW the battery works and it has electricty. thanks!
oh yea its a 92 cx with a d16y8 in it
Old Oct 11, 2004 | 12:10 PM
murmur9's Avatar
Default Re: help! my civic wont start! (29greencivic)
check the fuses
which fuse?
Old Oct 11, 2004 | 12:33 PM
00Red_SiR's Avatar
All Motor Mentor
Did you accidentially cross the jumper cables or momentarily hook them up backwards on your battery? Check the fuse box under the hood on the passenger side and see if you blew the main fuse in there. Examine all of them.
undertheradar's Avatar
Check the main fuses under the hood .
Old Oct 11, 2004 | 12:54 PM
i checked all the main fuses on the passenger side and even switched a couple around (of the same rating of course) to see if i could get any differnce. but nothing.
Old Oct 11, 2004 | 04:48 PM
Default Re: (29greencivic)
anybody????
Old Oct 11, 2004 | 05:14 PM
Gman8941's Avatar
check the ones in your interior near your left leg. if that doesnt work im thinking you ingition switch went bad or somthing, i dont know how to fix it but im sure someone does
Old Oct 11, 2004 | 06:05 PM
$300lude's Avatar
see if the battery cables are tight.
Old Oct 11, 2004 | 06:11 PM
Default Re: ($300lude)
they are tight, it has plenty of electricity.. the hazard lights blink really bright like they should. its like everything else is on a differnt circut or something.. i read stuff about a main relay but i dont know if thats what it is or how to test it either so...
oh to the post under me.. im a trial user so it wont let me post anymore today but nothing works... only the hazards.
Old Oct 11, 2004 | 06:17 PM
00Red_SiR's Avatar
All Motor Mentor
so can you turn your headlights on? what about windshield wipers? rear defrost? radio? when the key is turned forward.
Old Oct 11, 2004 | 06:53 PM
x_tc-Dae's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 29greencivic &raquo;</TD></TR><TR><TD CLASS="quote">they are tight, it has plenty of electricity.. the hazard lights blink really bright like they should. its like everything else is on a differnt circut or something.. i read stuff about a main relay but i dont know if thats what it is or how to test it either so...
oh to the post under me.. im a trial user so it wont let me post anymore today but nothing works... only the hazards.</TD></TR></TABLE>
just because your hazard lights work doesnt mean your car has good battery. i accidently left my headlights on for bout 45 minutes infront of wendy and the battery died on me. the car wouldnt start, but the radio workd, lights workd, just bout every electricity worked except it wouldnt start. so maybe you should try to jump again.
Old Oct 12, 2004 | 01:57 PM
Default Re: (ghost face)
i have tried jumping again and still.. nothing. any other ideas? i friend is coming over later with a multimeter thing so we will be checking fuses and stuff. anything i should check for? is there some sort of main relay that everything is on except the hazzard lights? any ideas are welcome.. i need to get this thing running!
Old Oct 12, 2004 | 02:19 PM
slambedcivic's Avatar
check ALL the wires.... in the fuse box, running to the starter...
all of them
Old Oct 12, 2004 | 05:50 PM
$300lude's Avatar
i'll see if I can find a wiring schematic.
Old Oct 12, 2004 | 05:56 PM
civiccpedx's Avatar
try depressing the clutch . Check all the fuses and the main relay. Also check to see if you have spark and fuel getting to the chamber.
NotAJDMFanBoy
Apr 21, 2020 08:21 PM
dings35
Honda CR-V & Element
May 27, 2013 06:23 PM
singlecamslamed
Mar 8, 2010 08:00 AM
egcivic
Jul 21, 2006 07:16 PM
WAT THA!!!
Oct 8, 2004 01:08 PM
