This combination sound good to you guys? Y8 N/A build (ALL OEM!)
Old Oct 11, 2004 | 11:35 AM
*Boostwerks*'s Avatar
Default This combination sound good to you guys? Y8 N/A build (ALL OEM!)
Well...mostly OEM
Y8 motor
Head is PNP
Zex Street/strip cam, Ti retainers/springs
PM6 pistons
PG6 rods
F4I ITBs
2 layer Y8 headgasket
CR came out to be roughly 10.4:1
Then just the basic Header/2.25" exhaust, and tuning.
I will be using either turboedit, or just a plain old PM6 with a VAFC.
Old Oct 11, 2004 | 11:50 AM
Thanks anyways, but I want to keep this as OEM as possible, for reliability and $ wise as well.
Old Oct 11, 2004 | 05:57 PM
uppity.
Old Oct 11, 2004 | 06:23 PM
Bserieskllr's Avatar
looks decent but i would want compression to be more around the 11.5:1 range and i hope its not a daily driver, cause daliy driver and itb's dont mix well.
Old Oct 11, 2004 | 08:06 PM
Default Re: (Bserieskllr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr &raquo;</TD></TR><TR><TD CLASS="quote">looks decent but i would want compression to be more around the 11.5:1 range and i hope its not a daily driver, cause daliy driver and itb's dont mix well.</TD></TR></TABLE>
I was going to use PM7 pistons but that gives me a 12.5CR which I think is just a little too high for a street car. Still undecided tho.
I've talked to 3 people that have had ITBs on their D series so far, and all of them said it would be fine for a DD. Even a TypeR with the 40mm bodys said you couldn't even tell it had ITBs until WOT. Its only as reliable as you can make it.
Old Oct 11, 2004 | 09:03 PM
1 Cam Wonder's Avatar
Default Re: (Bryson)
lol I bet the people with ITB's werent running a stock ecu with a VAFC.....
You will NEVER get your car to idle nicely, you will 100% be able to tell something is up unless you go with something other than the bandaid hack as for as management
Old Oct 12, 2004 | 09:54 AM
Default Re: (1 Cam Wonder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder &raquo;</TD></TR><TR><TD CLASS="quote">lol I bet the people with ITB's werent running a stock ecu with a VAFC.....
You will NEVER get your car to idle nicely, you will 100% be able to tell something is up unless you go with something other than the bandaid hack as for as management</TD></TR></TABLE>
dude... WTF did I say? Hrmm..."Turboedit". I know very well what I'm doing, and the idle for one is just based off the stock idle adjustment screw for the F4I. The only thing you really have to modify with the map is the last three colums of the fuel table since it doesn't take much throtal angle to reach atmosphere. I have a innovate wideband and will be doing the tuning my self.
As far as the hack goes...
https://honda-tech.com/zerothread?id=1010422
read up son.
Old Oct 12, 2004 | 10:16 AM
crx_88_si's Avatar
1g (d16a1) pistons should yeild around 11.5:1 CR
they early 86-87 d16 teg pistons are about 11.4:1
Old Oct 12, 2004 | 10:18 AM
Default Re: (crx_88_si)
Ooo. I guess I could just do all A1 internals then. Do you know if the 88-89 pistons are the same as the 86-87?
Old Oct 12, 2004 | 11:57 AM
Nerologic's Avatar
pg6b's milled flat
http://muller.net/sonny/pistons/
Old Oct 12, 2004 | 12:12 PM
weird...i was just talking with Sonny about those pistons.
Old Oct 13, 2004 | 09:53 AM
Nerologic's Avatar
wait, why not stick with pm6 rods??
Old Oct 13, 2004 | 09:59 AM
4drEF's Avatar
Keyboard Humorist
Default Re: This combination sound good to you guys? Y8 N/A build (Bryson)
I don't think Honda carries a specific Y8 head gasket.
Last time I checked the Y8 and Z6 both have the same part numbers.
I'm not sure how many layers the gasket is though.
Old Oct 13, 2004 | 10:27 AM
eL_cArLos's Avatar
Default Re: This combination sound good to you guys? Y8 N/A build (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">I don't think Honda carries a specific Y8 head gasket.
I'm not sure how many layers the gasket is though.</TD></TR></TABLE>
Its a three layer gasket I believe you have to remove the middle layer to have a 2 layer..
Old Oct 13, 2004 | 07:14 PM
The PG6 rods are way beefier than any late model D series. If I had a pic I would show ya...
I will actually be using the stock 3 layer gasket. I made up my mind on the pistons and will be using PM7s, so the stocker will do fine.
Old Oct 13, 2004 | 09:10 PM
civicsitek GanGsTa's Avatar
a1 pistons of the 88-89 variety will yield a compression &gt;12.5:1. I'd stick with the a6 pistons and swap the zex cam for an exospeed stage 3. That should work nicely with the itb's
Old Oct 13, 2004 | 09:19 PM
Nerologic's Avatar
Default Re: (civicsitek GanGsTa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">The PG6 rods are way beefier than any late model D series. If I had a pic I would show ya...
have u seen the size of 90-91 pm6 rods???
Old Oct 14, 2004 | 11:39 AM
Default Re: (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic &raquo;</TD></TR><TR><TD CLASS="quote">
have u seen the size of 90-91 pm6 rods???</TD></TR></TABLE>
Yeah and they're about the same size as the Z6, ZC, Y8...ect.
The PG6 is the largest of the D16 series rods.
I'm keeping the Zex cam mainly because it came with the head. And PM7s will net a CR of about 12.2 with a .048 gasket. I wouldn't use the A1 pistons because the valve releifs are tiny.
Old Oct 14, 2004 | 10:54 PM
Nerologic's Avatar
hmm...il hake to take one apart........
Hondacivic91dx
Nov 24, 2007 02:50 PM
FaceTuned
Jun 14, 2005 09:21 PM
99hatch
Feb 1, 2005 08:36 AM
EF_yo_89
Jun 28, 2004 12:22 AM
