frankenstien
Old Oct 11, 2004 | 09:15 AM
EF9 JAMS!!!'s Avatar
Default frankenstien
anyone ever done a frankenstien combonation? this guy i am going to buy my hatch from has a z6 i in it but the guy was trying to talk me into buying his frankenstien??? any info would be helpful.
thanks
Old Oct 11, 2004 | 09:19 AM
wtsexton's Avatar
Ah the retarded name for a ls/vtec or crvtec.
Old Oct 11, 2004 | 09:24 AM
s2k_al's Avatar
Default Re: (wtsexton)
They call it this because you use 2 different engine parts to build this. Ls bottom, si head etc.
capbyrd's Avatar
haha tim. if the "frankenstien" is built properly then it would be okay. but personally, i wouldnt take anyone elses motor project like that. i just dont trust other peoples work
Old Oct 11, 2004 | 09:42 AM
Default Re: (capbyrd)
well is it reliable, reasonable speed??? i mean i have never really heard of this term to describe this but i'm interested because everyone i have talked to says it's "okay" so....
Old Oct 11, 2004 | 10:13 AM
EVOLUTIONINNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capbyrd &raquo;</TD></TR><TR><TD CLASS="quote">but personally, i wouldnt take anyone elses motor project like that. i just dont trust other peoples work</TD></TR></TABLE>
yeap, you dont know how well the person did that put it together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch91JDM &raquo;</TD></TR><TR><TD CLASS="quote">well is it reliable, reasonable speed??? i mean i have never really heard of this term to describe this but i'm interested because everyone i have talked to says it's "okay" so....</TD></TR></TABLE>
i believe a stock LSVTEC puts down about 140-150whp. you have the tq of the LS and high end of teh VTEC head
Old Oct 11, 2004 | 10:39 AM
mrspeaker's Avatar
Default Re: (SiRhatchalot)
lsvtec's cant rev for **** if they're stock because ls blocks are very unstable after 7200rpm...
If I did lsvtec I would at least get a gsr girdle and arp bolts...
Old Oct 11, 2004 | 10:41 AM
michael O's Avatar
Default Re: (Mrspeaker)
I'd recommend doing it yourself unless you know the person who put it together.
Old Oct 11, 2004 | 10:52 AM
hahagasdcrx's Avatar
Default Re: (michaelOlson)
Read up on this. http://www.c-speedracing.com/h...c.php
this should give you some input on how it is all done.
Old Oct 11, 2004 | 11:06 AM
mrspeaker's Avatar
Default Re: (hahagasdcrx)
Dont need to go to a machine shop anymore to do ls vtec...
GE's lsvtec/b20vtec kit works great and requires no machining..
U can find them cheaper then what GE is sellin them for though..
http://www.goldeneaglemfg.com/...de=VC
Old Oct 11, 2004 | 11:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx &raquo;</TD></TR><TR><TD CLASS="quote">Read up on this. http://www.c-speedracing.com/h...c.php
this should give you some input on how it is all done. </TD></TR></TABLE>
it sounds like hatch91jdm, seems alittle bit of a noob to motors, so i wouldnt reccomend doin it himself imo. just to keep it on the safe side
Old Oct 11, 2004 | 11:36 AM
ijjz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRhatchalot &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like hatch91jdm, seems alittle bit of a noob to motors, so i wouldnt reccomend doin it himself imo. just to keep it on the safe side</TD></TR></TABLE>
He just wanted info, not to be called a 'noob' ok? People have to start somewhere regardless.
Old Oct 11, 2004 | 12:24 PM
speed_racer012's Avatar
Default Re: (ijjz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">Dont need to go to a machine shop anymore to do ls vtec...
</TD></TR></TABLE> Man thats good stuff. glad I just figured that info out! won't do it for a while.. well at least another year but when I do that will come in handy!
Old Oct 11, 2004 | 12:25 PM
LSvtec03's Avatar
Default Re: (ijjz)
read me
Old Oct 11, 2004 | 12:35 PM
capbyrd's Avatar
ok. honda tuning is doing a good write up of one this month. when i get home, i will scan it all in and show you.
the ls block is a good block but it needs a gsr or type r girdle to help hold things together and you need to get new bearings and forged rods as well as arp bolts to be able to "safely" rev into the upper rpms. a friend in town did an ls vtec and it puts down just a little over 190 with hondata tuned. you can make nice numbers but i think if you are spending all that time and money for that project, why not just go ahead and get a gsr and build it up right.
Old Oct 11, 2004 | 12:42 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">ls blocks are very unstable after 7200rpm...
um , sure.
you should really rethink that statement.
Old Oct 11, 2004 | 12:56 PM
CRX T-Si's Avatar
Gs-R motors are overpriced IMO nowadays.
You gotta learn about motors sometime, but since your in the military how will you find time to do this???
Old Oct 11, 2004 | 01:07 PM
mrspeaker's Avatar
Default Re: (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
um , sure.
you should really rethink that statement.</TD></TR></TABLE>
LS blocks are unstable at high rpms if they are stock due to the shitty stroke ratio.
So what are u talkin about..?
Old Oct 11, 2004 | 01:39 PM
608 Gangsta's Avatar
ls vtec
Old Oct 11, 2004 | 01:47 PM
LSvtec03's Avatar
So what are u talkin about..?</TD></TR></TABLE>
that was, and is, bs.
Old Oct 11, 2004 | 01:49 PM
mrspeaker's Avatar
Default Re: (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">
that was, and is, bs.</TD></TR></TABLE>
Explain how that is BS..
Old Oct 11, 2004 | 03:09 PM
LSvtec03's Avatar
Explain how that is BS.. </TD></TR></TABLE>
because the LS r/s ratio is hardly any worse than a gsr. nothing significant to worry about for any practical means
Old Oct 11, 2004 | 03:11 PM
mrspeaker's Avatar
because the LS r/s ratio is hardly any worse than a gsr. nothing significant to worry about for any practical means</TD></TR></TABLE>
I have my opinion on lsvtecs and u have yours so I'm not gonna argue anymore
Let's just squash this Bullshit..
Old Oct 11, 2004 | 06:02 PM
i take my ls block up to 8
Old Oct 11, 2004 | 06:48 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (LsFrnknstn)
I would not buy a LS/Vtec from anyone, unless I watched them put the thing together and they guarentee it.
One other thing to mention about LS/Vtec. Most people blow their engine because the oil pressure is not high enough when vtec kicks-in.
