oil not just leaking-----its pouring
Old Oct 11, 2004 | 07:43 AM
tkHBseries's Avatar
Default oil not just leaking-----its pouring
any of you accord guys know where leaks usually come from other than oil pan gaskets and oil filters???? Help! Oil is every where and dont know where else to start looking!
Old Oct 11, 2004 | 08:05 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: oil not just leaking-----its pouring (tkHBseries)
Head gasket?
Old Oct 11, 2004 | 08:58 AM
AllmansDB8*'s Avatar
Oil Seal, (balancer shaft), or some people call it front main seal...
Old Oct 11, 2004 | 09:16 AM
Turbowa's Avatar
Default Re: oil not just leaking-----its pouring (AllmansTEG)
What year accord and from what part of the engien is it leaking from?
Old Oct 11, 2004 | 10:10 AM
edd001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkHBseries &raquo;</TD></TR><TR><TD CLASS="quote">any of you accord guys know where leaks usually come from other than oil pan gaskets and oil filters???? Help! Oil is every where and dont know where else to start looking!</TD></TR></TABLE>
first thing to do is to look at the rocker cover seal as this is the most comman place for leakage and also the quickest to check.
have a look just under the distributer or at the back of the cover seal.
I have seen to meny people go for the hard stuff first like the head gasket or main oil seals only to find out all it is was the rocker cover.
check this first.
Old Oct 11, 2004 | 11:53 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmansTEG &raquo;</TD></TR><TR><TD CLASS="quote">Oil Seal, (balancer shaft), or some people call it front main seal...
front main is the crank seal, not the balancer shaft seal.
Old Oct 11, 2004 | 02:33 PM
tkHBseries's Avatar
Default Re: oil not just leaking-----its pouring (edd001)
rocker seal...is that the Valve cover gasket??????
well up top looks dry, head-gasket is okay, oil pan is okay, oil filter is okay....what is this about the crank seal....? where is it located and where is the balancer shaft located??? Oh...its a 94 accord f22b. non-vtec, and one other thing it drips right on to the exhaust pipe, if this helps any!!! Does the crank seal, rear main seal, or balancer seal sit above the exhaust pipe! How about the Axle output shaft seal...does this leak AT tranny fluid?
Old Nov 30, 2004 | 12:20 PM
jmlude's Avatar
Hey I was wondering if you had this problem fixed yet. I was having the same problem with my Prelude and it ended up being a seal that needed to be replaced behind the enginer oil cooler, which is the part the oil filter sits on. Supposedly this rubber seal goes bad around 60,000 miles and is one of the parts that is replaced when you take it into the dealer for that mileage inspection. Well the part costs about $3.00 and should take an hour or less to fix.
Old Nov 30, 2004 | 12:49 PM
Schmitey's Avatar
Default Re: oil not just leaking-----its pouring (jmlude)
you obviously don't know the basic layout of your engine...
crankshaft and balance shafts run parallel with the engine block...so left to right
your pulleys (and seals) are on the drivers side (except for the output shaft side, but that rarely leaks and would lead on the exhaust) , the reason ppl are saying balance shaft seal is because there was a recall on some makes because the seal could pop out and you lose all your oil in a second
and your TWO axle seals (you got two axles go figure) wouldn't be leaking much and it would be ATF
More than likely if its leaking onto your exhaust its coming from the backside of the engine, oil filter is probably loose or something.
quit playing what if, just follow the leak up until you don't see any more oil!
Old Nov 30, 2004 | 02:24 PM
matt_in_sd's Avatar
If nothing else helps, start it up. If the leak is that bad you will see it real quick.
swertepinoy
Feb 27, 2010 10:55 PM
captainkickass
Mar 27, 2009 07:10 PM
tw1nny03
Mar 3, 2008 05:29 AM
sickofitall1113
Jun 6, 2007 07:58 PM
vietkangta
Sep 21, 2006 09:21 PM
