will the d16a1 bolt up the 1st gen crx si tranny
Old Oct 10, 2004 | 07:43 PM
illogic65's Avatar
Default will the d16a1 bolt up the 1st gen crx si tranny
will the d16a1 black top engine bolt up to my 87 crx si tranny? please let me know
Old Oct 10, 2004 | 09:02 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: will the d16a1 bolt up the 1st gen crx si tranny (illogic65)
Sorry but no. Strangly enough, the only engines/trannys that have the same bellhousing bolt pattern are the brown top and <U>early</U> black top JDM dohc ZC's, AND the 84-87 4wd Civic wagons. Note, it is ONLY the 4wd wagons with the same bellhousing, but their tranny is pretty much useless with a D16A1. However you CAN just swap both the D16A1 and its tranny into 84-87 Civics/CRXs. Since you've got an Si with MPFI you are already halfway there. Read the FAQ and search at http://www.redpepperracing.com to learn more about it. Good luck with that. IM or email me if you've got questions.
hazrd420
Aug 3, 2007 08:58 PM
eguti66
Dec 1, 2006 11:15 AM
efHondefender
Oct 4, 2005 02:50 PM
EFb18b
Apr 25, 2005 06:19 AM
help me
Aug 11, 2004 08:53 AM
