88-91 Si Trans All Interchangeable? (Some weird info to change opinions)
Old Oct 10, 2004 | 05:23 PM
1 Cam Wonder's Avatar
Default 88-91 Si Trans All Interchangeable? (Some weird info to change opinions)
I searched and found both answer, so being the noob, I might as well follow the trend and start a post with a generic question.
My question is, I own an 88 Crx Si (originally from canada) and I swapped in a sohc zc, I dont know what year the engine is but I was told it was a never year because my throttle body only has a hole for an IACV and not an FITV
I just wanna know if it matters or not what year tranny I buy as long as its from an 88-91 Si?
Old Oct 10, 2004 | 06:03 PM
Targa250R's Avatar
be professional
Default Re: 88-91 Si Trans All Interchangeable? (1 Cam Wonder)
'88 transmissions have a different spline count vs. '89-91 transmissions. You can use the '88 tranny, however you also have to use an '88 clutch with it. '89-91 clutches will not work on an '88 trans.
Old Oct 10, 2004 | 06:09 PM
nikitad's Avatar
Default Re: 88-91 Si Trans All Interchangeable? (Targa250R)
And 88 flywheel to go withthat clutch - pretty much take them both from your old motor and put them on the new one.
Old Oct 10, 2004 | 06:11 PM
Default Re: 88-91 Si Trans All Interchangeable? (nikitad)
hmmmmm ****
I dont know then. The car is an 88 Si, but I dont know what year the tranny is...
If i got some numbers off of the tranny would you guys be able to tell me anything from just the serial on the front of the block stamp on the tranny?
Old Oct 10, 2004 | 07:05 PM
nikitad's Avatar
Here is the magic info everybody seeks:
Tell the year of CRX tranny the easy way.
http://norcalcrx.org/nikita/crx/tranny2.jpg
Floored
Jun 8, 2005 06:59 AM
EF_9
May 24, 2005 10:36 PM
jadugartir
Aug 7, 2004 12:34 PM
balistic CRX
Jan 23, 2002 06:32 AM
crxnug
Aug 2, 2001 09:31 PM
