oil inside my radiator??? help ??
Old Oct 10, 2004 | 04:24 PM
BlazeTeck2000's Avatar
Default oil inside my radiator??? help ??
my friends 91 integera has oil in the radiator and don't know how the **** this is going on but its all oil in it ... he didn't put oil in it it just started to do that....it over heats and smokes out white any help anyone ?"
Old Oct 10, 2004 | 04:25 PM
Dan GSR's Avatar
Default Re: oil inside my radiator??? help ?? (BlazeTeck2000)
headgasket is blown
Old Oct 10, 2004 | 04:34 PM
Default Re: oil inside my radiator??? help ?? (Dan GSR)
and this is for sure right /?? is it hard to change this ?? if it is whats the going rate to fix it???
Old Oct 10, 2004 | 04:40 PM
mattcalica's Avatar
yah, the headgasket is most likely blown...DO NOT DRIVE THE CAR anymore...fix it...it is not that hard, but i have no clue what your mechnics skill level is. basically, you have to disconnect the wiring harness, disconnect exhaust manifold...take out cams, under the cams there are 8 or 10 headbolts (i can't remember) take those off from outside in (meaning take off the outside bolts in a cross pattern and take off the middle bolts last) and pull off the head to get to the headgasket. i could do it in like an hour, so its really not too hard...might wanna get a helms manual to give you a more detailed description...
Aodhan
20
Oct 24, 2007 01:58 PM
inland180
Mar 27, 2007 10:56 AM
nathanie1
Nov 21, 2005 07:22 PM
LShatchie
Welding / Fabrication
Jun 8, 2005 01:54 PM
mykeshonda
Sep 28, 2004 06:04 AM
