d16z6 with cable tranny....what clutch???
Old Oct 10, 2004 | 02:40 PM
bigblueandyellow's Avatar
Default d16z6 with cable tranny....what clutch???
Hey guys, im replacing my motor in my car (d16z6) and it came with the hydro tranny.....But im going to use the cable tranny from an si, just wanna know what year clutch i should be lookin for, are they all the same?
Thanks guys
Old Oct 10, 2004 | 02:55 PM
-16V-'s Avatar
Default Re: d16z6 with cable tranny....what clutch??? (bigblueandyellow)
I heard u could use a forth gen si clutch...
Old Oct 10, 2004 | 03:03 PM
lhd dc2's Avatar
It depends on what yr tranny your using. 88-89 or 90-91 cable si tranny uses different spline.
Old Oct 10, 2004 | 04:02 PM
slywfbpsi's Avatar
Default Re: d16z6 with cable tranny....what clutch??? (LHD Hatch)
If you have an 89-91 you can use a 90-91 clutch. I have a 89 si tranny and I'm using a 91 clutch for my d15b vtec. 88 is the only wierd year.
Old Oct 10, 2004 | 04:22 PM
CRXBart's Avatar
Default Re: d16z6 with cable tranny....what clutch??? (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">If you have an 89-91 you can use a 90-91 clutch. I have a 89 si tranny and I'm using a 91 clutch for my d15b vtec. 88 is the only wierd year.</TD></TR></TABLE>
correct, kinda. the clutch disc diameter was smaller in 89 so to use 90-91 you will need the 90-91 flywheel also. I'm using a 90 DX tranny with the Z6 and I'm using a stock z6 clutch, it works, but the pedal is more stiff than stock, not bad though. As long as you have an 89-91 you should be fine, I would just get a clutch for whatever year tranny you have. Make sure you use the correct year flywheel in conjunction with it.
Old Oct 10, 2004 | 05:12 PM
91civicEX's Avatar
i read on some mini-me write up or z6 swap write up that the 92-95 clutch is bigger but it might have been the flywheel. just some more info for ya. i got the 91 si clutch in my z6/si tranny
Old Oct 10, 2004 | 05:52 PM
The DX Rex's Avatar
Default Re: d16z6 with cable tranny....what clutch??? (91civicLX)
i got 89 hatch dx wit a d16z6, stock dx tranny, wit an act clutch and fidanza flywheel for 92-95 civic
Old Oct 21, 2004 | 05:02 AM
so would a 92-95 flywheel work with the 89-91 si clutch on an 89-91 si tranny....thats pretty much what im lookin for?
Old Oct 21, 2004 | 05:17 AM
Brownjd's Avatar
Default Re: (bigblueandyellow)
i think you have to use the same flywheel/clutch, like you can use the 92-95 civic flywheel/clutch or the 89-91 flywheel/clutch. so depends on which flywheel you use.
Old Oct 21, 2004 | 06:12 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblueandyellow &raquo;</TD></TR><TR><TD CLASS="quote">so would a 92-95 flywheel work with the 89-91 si clutch on an 89-91 si tranny....thats pretty much what im lookin for?</TD></TR></TABLE>
yes. the only difference in the 92+ flywheels from the 90-91 is weight. they're lighter.
lmananT
Jun 20, 2008 04:55 PM
helpmycivic
Jan 16, 2008 09:24 PM
down_the_hatch
Aug 30, 2005 11:43 PM
s2kkk
Aug 14, 2004 05:57 PM
egchan
Oct 6, 2003 01:28 PM
