If I buy a new clutch for my car do I need a new flywheel as well?
Old Oct 10, 2004 | 02:36 PM
hondaracin24's Avatar
Default If I buy a new clutch for my car do I need a new flywheel as well?
According to prostreetonline.com after looking for some new clutch's they say you either need a new flywheel with the new clutch or get the old one resurfaced which would cost around $80. What's your take on this? Should I get the flywheel as well and spend the extra money or get the old one resurfaced? As for clutches is Exedy a good brand to look at? Thanks for anyones help....
Old Oct 10, 2004 | 03:53 PM
madd's Avatar
Default Re: If I buy a new clutch for my car do I need a new flywheel as well? (hondaracin24)
well this all depends on your application. they make lightened flywheels and all that. if you arn't going for performance then just get the stock one resurfaced. I have really never heard anything bad about Exedy....there are better, but when you dont have 1300 to blow on a clutch, the Exedy is great
knowing why you are buying the clutch and what you plan on doing to your car will greatly aid in yielding a better response.
Modified by madd at 10:01 PM 10/10/2004
Old Oct 10, 2004 | 05:45 PM
TOAB's Avatar
shop around, take your flywheel to a machine shop... just about any machine shop. i got mine done for $35
Old Oct 10, 2004 | 07:26 PM
Schmitey's Avatar
Default Re: (TOAB)
no, i definitely suggest measuring the specs to see if it works (I was lucky my dad had the tool, spectrometer I think its called)
it is a myth that resurfacing will help your grip, yes maybe initially but eventually the surface will glaze over and get smooth again
Old Oct 10, 2004 | 07:38 PM
StimpyBoy's Avatar
Default Re: (Schmitey)
Resurfacing just to remove glaze is, yes, not helping that much. However, if one can feel ridges with a fingernail, even smoothed ridges, in the flywheel then a resurfacing is advised. If the surface is smooth, then an emory paper treatment can probably suffice.
When I replaced my stock clutch at 170K KM, the flywheel had very definite "channels" worn into it. A resurfacing in that case is recommended.
Also, Exedy Organic
Old Oct 11, 2004 | 04:23 AM
Monkey Fing a Coconut's Avatar
Default Re: If I buy a new clutch for my car do I need a new flywheel as well? (madd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madd &raquo;</TD></TR><TR><TD CLASS="quote">I have really never heard anything bad about Exedy....there are better, but when you dont have 1300 to blow on a clutch, the Exedy is great
Modified by madd at 10:01 PM 10/10/2004</TD></TR></TABLE>
$200 exedy or $1300 other clutch, man thats a big jump....
anyways, ive had my exedy organic with act 12lb flywheel on my h22 for 6 months now and no probs whatsoever, if its holdin up on the h22 itll be perfectly fine for stock accord motor
Old Oct 11, 2004 | 04:38 AM
PrettyLude's Avatar
it will be convenient to resurface the flywheel since its all going to be out
Old Oct 11, 2004 | 07:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madd &raquo;</TD></TR><TR><TD CLASS="quote">knowing why you are buying the clutch and what you plan on doing to your car will greatly aid in yielding a better response.
Im just looking for an OEM clutch. No sport clutch or race clutch is something that I really had in mind right now. But if you figure the exedy organic oem clutch is $250 and to resurface the flywheel would be an estimate of almost a $100 and I could get the clutch and flywheel for $400. Do you think Id be better off with just that? I got the bigger rims 17" and now Im really noticing my clutch slipping. What about act or centerforce clutchs? How do they compare to Exedy?
Old Oct 11, 2004 | 07:24 AM
madd's Avatar
Default Re: If I buy a new clutch for my car do I need a new flywheel as well? (twistedbydezign)
i was referring to the high end shiz...the name slips my mind tho....
Old Oct 11, 2004 | 07:34 AM
Two_K Si's Avatar
Go with the clutch + light flywheel combo. Light flywheels feel great.
Old Oct 11, 2004 | 07:42 AM
Default Re: If I buy a new clutch for my car do I need a new flywheel as well? (Two_K Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">Go with the clutch + light flywheel combo. Light flywheels feel great. </TD></TR></TABLE>
Will it give me more bottom end in the lower rpm's?
Old Oct 11, 2004 | 07:44 AM
brads94accord's Avatar
ive got a stock f22 flywheel that needs to be resurfaced i will let go for $40 plus shipping. i recommend resurfacing it. a friend of mine did the emory cloth treatment and now hes got a lot of clutch chatter starting off.
Old Oct 11, 2004 | 08:40 AM
Two_K Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaracin24 &raquo;</TD></TR><TR><TD CLASS="quote">
Will it give me more bottom end in the lower rpm's?</TD></TR></TABLE>
There are many topics and debates on flywheel weights, so try searching. With a light flywheel, your engine will rev quicker/more freely throughout the entire rev range.
Old Oct 11, 2004 | 11:31 AM
Jay84ever's Avatar
How bad does you old one look?
Old Oct 11, 2004 | 11:42 AM
Schmitey's Avatar
Are you serious? For what I paid Exedy was the only option and its done great for me. For the record take a close look at ACT next time. They look schockingly like a repainted Exedy clutch, I've seen a lot of debate on this topic but I'm skeptical. Not to mention ACT charges a hell of a lot more for pretty much the same clamping force.
and the flywheel thing is overrated. I am HIGHLY skeptical that it will give you any more horsepower, and if it does definitely not 20+ like some bogus products claim. IF ANYTHING your engine will rev faster, flywheels are really made for turbo apps that need a fast spool up. I'm sure I'm gonna be yelled at for this one but from what I've seen that's the case. Granted I don't have aftermarket flywheel in my ride, but that's what I've seen with my buddy's turbo ride.
Old Oct 11, 2004 | 12:08 PM
rudeman85's Avatar
Default Re: If I buy a new clutch for my car do I need a new flywheel as well? (Schmitey)
I don't know about you guys, but, i purchased a Fidanza 8.5 lb flywheel with and exedy clutch, all in all cost about 375 for the both. A good shop right down the street charged me 400 for installation, i know a little steep...but they do good work and are trustworthy. Overall I love it, the f22 non-vtec has suprisingly some ***** with it now .
Old Oct 11, 2004 | 12:10 PM
ForceThis!'s Avatar
just get it resurfaced and you'll be fine. end of story, about 30-40 bux out of pocket
Old Oct 11, 2004 | 03:08 PM
Default Re: If I buy a new clutch for my car do I need a new flywheel as well? (ForceThis!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceThis! &raquo;</TD></TR><TR><TD CLASS="quote">just get it resurfaced and you'll be fine. end of story, about 30-40 bux out of pocket</TD></TR></TABLE>
That makes things less complicated. Thanks....
Old Oct 11, 2004 | 03:25 PM
Sublime95's Avatar
I replaced the clutch on my 90 Accord after the factory one finally went out. I bought a Centerforce Dual Friction for around $250. I really liked it considering the factory clutch was about the same price. For a old Accord with 220,000+ third gear scratch felt pretty nice.
Exodus1811
Dec 24, 2003 03:58 PM
teg92
Mar 24, 2003 12:55 AM
