installing rear brake pads
Old Oct 10, 2004 | 01:51 PM
89JDMcrx's Avatar
Default installing rear brake pads
ok I'm ready to install the new brake pads on the rear caliper, but I'm having trouble compressing the piston. Do I need to take off the brake line and drain the fluid off the caliper to compress it? thanks
Old Oct 10, 2004 | 01:54 PM
B16 ED9's Avatar
Default Re: installing rear brake pads (97exracer)
No don't take out the break lines, here is what I did when my old pads were out, I took the old pad and put it up against the piston, and took a C- clamp tightened it until the piston was compressed
Old Oct 10, 2004 | 02:00 PM
abnaasefmb's Avatar
Default Re: installing rear brake pads (B16 EF)
listen to this guy it will save you some trouble
Old Oct 10, 2004 | 02:27 PM
89JDMcrx's Avatar
Default Re: installing rear brake pads (abnaasefmb)
well I tried the c-clamp and it seems the piston won't compress. How big was the C-clamp that you used?
Old Oct 10, 2004 | 03:13 PM
B16 ED9's Avatar
Dont tell me you used one of those small *** C-Clamps, The one that I used was the biggest C-clamp, I dont have a digital cam to post a pic, or else I would of. find the biggest C-Clamp you can
Old Oct 10, 2004 | 03:49 PM
89JDMcrx's Avatar
i have a 7" clamp pretty huge, i tighten the clamp as much as I can and its still not compressing.
Old Oct 10, 2004 | 03:55 PM
B16 ED9's Avatar
hummmmm it should of worked, I have change all of my breaks myself like 4 times, and evrytime I used the C-clamp to compress the piston worked everytime You might have a problem with the pistion
Old Oct 10, 2004 | 05:31 PM
89JDMcrx's Avatar
Well I found out the problem of why they wouldn't compress. Well I did some research and found out the rear caliper dosen't compress like the front ones. There is a special tool that turns the piston. Like screwing a screw, it compress when I turned it to the right and it comes out when its going left. I didn't know that the piston did that.
Old Oct 10, 2004 | 05:56 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 EF &raquo;</TD></TR><TR><TD CLASS="quote">No don't take out the break lines, here is what I did when my old pads were out, I took the old pad and put it up against the piston, and took a C- clamp tightened it until the piston was compressed </TD></TR></TABLE>
Do NOT compress the piston in a rear caliper!!! You can damage the caliper that way. ONLY do this with front calipers!
Rear caliper pistons have to be TURNED - which is why they have the slots in them. You can buy a tool specifically to turn rear caliper pistons, or you can improvise . . .
Edit: I just read that the original poster found the proper way to do it.
Old Oct 10, 2004 | 06:09 PM
B2FiNiTY's Avatar
Default Re: installing rear brake pads (Targa250R)
Why are you guys giving this guy bad advice? He could have damaged his brakes
Use the special tool or just find a large flat head to turn the piston.
Old Oct 18, 2004 | 10:41 AM
JokerTypeR's Avatar
Default Re: installing rear brake pads (B2FiNiTY)
Dont' have rear discs yet, but soon will. This will be much help. Thanks ya'll...
Old Oct 18, 2004 | 10:51 AM
crx_88_si's Avatar
Default Re: installing rear brake pads (JokerTypeR)
also, don't forget to release the e-brake!
turbo-crx
Jan 19, 2009 03:32 PM
leviq
Jul 7, 2007 08:28 AM
lowered94accord
Apr 19, 2007 11:46 AM
LudeChild
Nov 16, 2004 05:27 PM
AzianAvenger
Jun 21, 2002 10:21 AM
