symptoms of blown head gasket?
Old Oct 10, 2004 | 12:30 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default symptoms of blown head gasket?
I'm pretty certain mine is fine, but I'm just wanting to make sure...
When I drained the coolant out of my block last weekend to change my water pump, it looked kinda dark. I don't think it was oil, it was probably just dirty, and also because I was looking at it in a bright yellow drain pan, but anyway, what would be symptoms of a blown head gasket besides oil in the coolant? My car runs fine, idles solidly at 750 rpm, acclerates smoothly (especially now that I finally got some axles that don't vibrate), does not consume a drop of oil that I can tell on the dipstick, average 32-34 mpg, regularly get 350-370 miles or more per tank, and all 4 plugs had a normal grayish appearance when I took them out and replaced them last weekend. So what do you think, should I worry about a blown headgasket? Would it cause any of those above things I listed to suffer, like performance or fuel economy?
Old Oct 10, 2004 | 01:13 PM
gsrboi80's Avatar
Default Re: symptoms of blown head gasket? (PatrickGSR94)
The car would run shitty and you would see an abundance of white smoke from the exhaust. The dark coolent is probably just crap from your radiator. Not to worry.
Old Oct 10, 2004 | 02:19 PM
Eddiebx's Avatar
yeah if you had oil in ur coolant, u'd know it. don't worry too much just yet. if you really wanna be safe do a leak down test.
Old Oct 11, 2004 | 10:15 AM
psychotic_z's Avatar
Default Re: (Eddiebx)
Patrick... I just blew my own head gasket about a week or two ago (not sure exactly when it happened) and I realized it this last Thursday. But, you KNEW something was wrong - from the white smoke from the exhaust, the coolant puddling in the exhaust tip ( ), crappy idle, and rough acceleration...
You can do a leakdown test and/or a compression test to be sure. A compression test was all I needed to be sure mine blew ... 30, 30, 120, 150 .
Old Oct 11, 2004 | 10:44 AM
Sack Master's Avatar
Default Re: (psychotic_z)
If you had a blown or leaking head gasket you would know it. Either oil in your coolant, coolant in your oil, burning coolant, leaking oil on the outside of the block, overheating. Probably a few other symptoms but probably nothing you just explained.
Old Oct 11, 2004 | 11:18 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
you wouldn't be able to drive for more than 15-20 min TOPS. Your car would overheat severly. I toasted the block in my parents' 88 caravan with a blown head gasket just drivin 3 miles from work to home.
Old Oct 11, 2004 | 12:29 PM
Gerbilo's Avatar
Default Re: symptoms of blown head gasket? (marsbike)
On a road trip me and a friend blew the headgasket on his Jeep. We knew it right away, we were just hoping we could make it to a rest stop or something. The temp was in the red the whole time, white smoke was coming out of the tail pipe and under the hood, and it lost all performance. It only took a short while for it to go from "just a lil hot" to completely killing the car.
Old Oct 11, 2004 | 12:43 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">If you had a blown or leaking head gasket you would know it. Either oil in your coolant, coolant in your oil, burning coolant, leaking oil on the outside of the block, overheating.</TD></TR></TABLE>
def. what this guy said
Old Oct 11, 2004 | 01:20 PM
vidanator's Avatar
Default Re: (NightRider-gsR)
not to steal ur thread or anything patrick, but now i'm a little concerned, u said ur spark plugs were grayish, mine are brownish not too light and not too dark, just brown, so is there something wrong with my engine?
Old Oct 11, 2004 | 01:56 PM
Default Re: (vidanator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vidanator &raquo;</TD></TR><TR><TD CLASS="quote">not to steal ur thread or anything patrick, but now i'm a little concerned, u said ur spark plugs were grayish, mine are brownish not too light and not too dark, just brown, so is there something wrong with my engine?</TD></TR></TABLE>
No, golden brown plugs are normal.
Old Oct 11, 2004 | 03:35 PM
Community Builder
well yeah, brownish with maybe a little gray... all 4 of my plugs looked normal according to the pics in the back of the Haynes manual.
Sweet, nothing wrong with my car, gotta love Hondas.
About that Jeep, it didn't warp the block or heads did it (driving it in the red zone)?
Old Oct 12, 2004 | 08:17 AM
Gerbilo's Avatar
Default Re: (PatrickGSR94)
Pistons were scorched pretty bad, the 1-2 cylinders(it's an I6) were starved for oil and it got roughed up pretty badly. Ended up just replacing the block/bottom end because there was a spare one laying around.
it was a jeep w/ 130,000 violent miles, it was time lol
jspinelli8
Mar 26, 2018 01:31 AM
dc2_dude
Feb 13, 2009 12:12 AM
ef 991red
19
Jan 20, 2009 04:28 AM
ericstambaugh07
Jun 25, 2007 09:08 AM
PatrickGSR94
Mar 5, 2003 10:02 PM
