If i get new pistons???
Old Dec 15, 2001 | 05:18 PM
Adampops's Avatar
Default If i get new pistons???
If i get new pistons (JE 10.5:1) will i be increasing horsepower over the stock pistons on a 94 integra rs (non-vtec, b18b). Isnt the cr on the stock pistons 9.2:1. So if i get these 10.5:1 cr pistons, i will see power difference, right??? Is there anything i need to watch out for if i raise my cr on my pistons????
Old Dec 15, 2001 | 05:22 PM
Malice's Avatar
New User
Default Re: If i get new pistons??? (Adampops)
10.5 is pretty damn safe, nothing to worry about there. you will notice alot more torque
Old Dec 15, 2001 | 05:26 PM
Adampops's Avatar
Default Re: If i get new pistons??? (MaliceGSR)
How high of a cr can i go before it starts getting dangerous??? doesnt the itr have a cr in the 11's. i think thats for the jdm version. Could i get pistions with a cr of around 11??? or am i talking unsafe?? thanks
Old Dec 15, 2001 | 05:30 PM
Malice's Avatar
New User
high 11's up to 12's is getting in the danger zone
Old Dec 15, 2001 | 05:31 PM
fsarfino's Avatar
I would say 12.0 or so would be safe also rembember that this is static CR and when the engine is running cam tuning also affects CR if you have overlap dialed in like most honda's it lowers CR and also think about highest grade octane avail. in your area.
Old Dec 15, 2001 | 05:38 PM
Adampops's Avatar
Default Re: If i get new pistons??? (dohcvtec16)
So lets say JE makes a piston with a cr of like 11.5:1??? Do you think this would be safe??? Would i see that much of a difference between 11.5:1 and 10.5:1??? Is it worth it??? Thanks.
Old Dec 15, 2001 | 05:41 PM
Adampops's Avatar
So lets say JE make some 11.5:1 pistons, would that be okay??? Would i see that much of a difference between 11.5:1 and 10.5:1??? is it worth it??? Thanks
Old Dec 15, 2001 | 05:42 PM
Adampops's Avatar
sorry for the double post i didnt think the first one went through!!!
Old Dec 15, 2001 | 10:48 PM
Vtec integra's Avatar
if everything is done right it'll be worth it. just break in the rings right.
and consider in investing in some cams. cams love the higher compression.
after that an intake manifold and bigger throttlebody.
11's are safe
after 12's you'll need to add octane boost to your gas after that
or you'll hear ticking and detonation
Old Dec 16, 2001 | 08:20 AM
Tomakit's Avatar
Default Re: If i get new pistons??? (Vtec integra)
b18b1 - 9.2
b18c1 - 10.0
b18c5 - 10.6
11.5 you can run, if you can get premium gas all the time. and for every point that you raise the cr, you gain 3-4% hp across the board. (general rule)
Tom
Old Dec 16, 2001 | 08:23 AM
Adampops's Avatar
Default Re: If i get new pistons??? (Tomakit)
So what cr do you think is good if i just run regular and medium gas??? how bout just 11.0:1. Can i run this high of a cr with just regular gas?? thanks
narfdanarf
Aug 7, 2009 02:50 PM
HmgLauj69
May 24, 2009 02:28 PM
PrecisionH23a
Mar 17, 2005 06:12 PM
TurboT
Nov 28, 2001 01:42 PM
