question about dizzy coil wires
Old Oct 10, 2004 | 11:29 AM
hatchinprogress's Avatar
Default question about dizzy coil wires
ok people i need help hookin up my msd coil but i cant get the coil(from dizzy) off so i need to know if the 2 wires are on the outside of the cap? it looks as if they are but im not 100% . also if i can get to the coil wires outside of the dizzy can i leave the coil in the dizzy or will that mess somethin up? remember i cant get the screws out of the dizzy. and my dizzy is bad(throwin code) so i plan on buyin another one in the future and thats why i dont wanna waste anymore time on this dizzy. someone please help
Old Oct 10, 2004 | 11:30 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: question about dizzy coil wires (hatchinprogress)
Bump... I'd like to know also.
Old Oct 10, 2004 | 11:35 AM
DieMaster's Avatar
Needs to be About 20% Cooler
are u talking about the primarey side of the coil? if so the 2 pin plug is that. The BLK/YEL is + and the BLUE is the - tach signal
Old Oct 10, 2004 | 11:39 AM
Default Re: question about dizzy coil wires (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">are u talking about the primarey side of the coil? if so the 2 pin plug is that. The BLK/YEL is + and the BLUE is the - tach signal</TD></TR></TABLE> well im not sure these wires are on the bottom of the dizzy, and i know there is a blue wire that you tap into for a tach. so to your question i dont think so
Old Oct 10, 2004 | 12:09 PM
bump for help
Old Oct 10, 2004 | 12:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote">bump for help </TD></TR></TABLE>
Old Oct 10, 2004 | 03:34 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Old Oct 10, 2004 | 03:39 PM
Banned
Default Re: question about dizzy coil wires (street dreams)
these?
Those wires aren't doing **** for my MSD Rev Control, they are probably the wrong wires.
I was told I need to run them directly to the coil inside the dizzy.
Old Oct 11, 2004 | 01:12 PM
Default Re: question about dizzy coil wires (LSVTEC 91 Civic)
yeah thats wrong on my car i had to put a small hole in the cap and run the wires (red and white) directly inside the dizzy. and by the way msd has instructions on there site if u need help http://www.msdignition.com/downloads.html
Old Oct 12, 2004 | 07:40 AM
Banned
Hatchinprogress...
I contacted MSD - It must be wired between the ignitior and the coil, which is inside the distributor cap.
Old Oct 12, 2004 | 10:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Hatchinprogress...
I contacted MSD - It must be wired between the ignitior and the coil, which is inside the distributor cap.</TD></TR></TABLE> i did that, but my prob is i cant get the stock coil out so i just cut the wires and connected the msd wires to thelil "plugs" but now it wont start i think i screwed somethin up....
Old Oct 12, 2004 | 12:18 PM
gringo7718's Avatar
all you need to do is access the wires at the coil.
1. remove your dist cap.
2. notice the coil wires blk/yel + and white/blue -
3. disconnect wires from coil.
4. tape up and extend them outside the dizzy throug the grommet.
5. connect the new extended wires to your new coil.
note both coils cannot be connected at the same time
Old Oct 12, 2004 | 01:51 PM
Default Re: question about dizzy coil wires (gringo7718)
why cant u get the coil out did u remove all the screws
Old Oct 12, 2004 | 08:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams &raquo;</TD></TR><TR><TD CLASS="quote">why cant u get the coil out did u remove all the screws</TD></TR></TABLE> the screws wouldnt turn they would just strip (real old screws) i used wd-40 on screws no luck, but i just got them out (about an hour ago) but now i think theres problems with the msd ignition (i cant get the pills to work) damn
Old Oct 13, 2004 | 02:33 PM
Banned
[QUOTE=hatchinprogress] the screws wouldnt turn they would just strip (real old screws) i used wd-40 on screws no luck, but i just got them out (about an hour ago) but now i think theres problems with the msd ignition (i cant get the pills to work) damn
Go to http://www.msdignition.com, then to "Tech Forums".. Thats where I found help, make a post there.
Old Oct 13, 2004 | 02:36 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchinprogress &raquo;</TD></TR><TR><TD CLASS="quote"> the screws wouldnt turn they would just strip (real old screws) i used wd-40 on screws no luck, but i just got them out (about an hour ago) but now i think theres problems with the msd ignition (i cant get the pills to work) damn </TD></TR></TABLE>
wd-40 is not a penetrating lube, use pb blaster.
Old Oct 13, 2004 | 02:54 PM
ThatRicerDaniel's Avatar
Default Re: question about dizzy coil wires (90blackcrx)
damn ghetto.
get a pnumatic drill and a hammer. there like 15 bucks at harbor freight.
jonnyt1130
Aug 3, 2009 04:55 PM
digital sol
10
Jul 25, 2007 08:38 PM
whiteboy03si
Feb 21, 2007 10:01 PM
n00bs suck
Dec 9, 2004 08:47 PM
hatchinprogress
Oct 11, 2004 01:02 PM
