spark plugs swimming and coverd in oil??? huh????
Old Oct 10, 2004 | 12:45 AM
93FastLs's Avatar
Default spark plugs swimming and coverd in oil??? huh????
went to change my spark plugs in my car. just recently did a c5 swap into it. took the boots out and all 4 spark plug holes are filled with oil! ?? has anyone ever heard or seen this before if so, why did it happen ? please respond back asap if possible
Old Oct 10, 2004 | 02:04 AM
murmur9's Avatar
Default Re: spark plugs swimming and coverd in oil??? huh???? (93FastLs)
seals
Old Oct 10, 2004 | 02:42 AM
VeilSide_Mas's Avatar
Default Re: spark plugs swimming and coverd in oil??? huh???? (murmur9)
Bad valve seals
Like mine
Old Oct 10, 2004 | 02:56 AM
eL's Avatar
eL
sorry to jack the thread but would burning oil at high rpms also be the valve seals? if so... how is this replaced and how much $ are we talking?
Old Oct 10, 2004 | 02:59 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: (eL)
Take your valve cover off and make sure you have the little round seals installed on your valve cover where the spark plugs go though the valve cover......This exact thing happened to me awhile back.....
Old Oct 10, 2004 | 03:24 AM
Default Re: (92 civic VX B18c)
Hmm is it easy to change the valve seals? Mine is burning oil whenever I floor the throttle and losing compression bad..
Does having bad valve seals cause a whole lot of compression lost?
Yea burning oil could also be your piston rings seal which would mean bigger trouble, take out the whole engine and replacing piston rings/seal at a machine shop would cost u a ton unless u change it yourself
Old Oct 10, 2004 | 03:32 AM
stripes777's Avatar
ya make sure your O ring seals are installed, and make sure you tighten up the valve cover so the gasket gets pressed down. at least u dont have oil in your cylinder, like what i had before..
Old Oct 10, 2004 | 09:18 AM
specv5150's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 civic VX B18c &raquo;</TD></TR><TR><TD CLASS="quote">Take your valve cover off and make sure you have the little round seals installed on your valve cover where the spark plugs go though the valve cover......This exact thing happened to me awhile back.....</TD></TR></TABLE>
Yeah check the simple stuff first. DOnt alway assume the worst. Mine did the same thing after I installed turbo. I was thinking all kinds of things and having to spend alot of money.....I ended up spending less than 10 bucks to fix it. I bought new valve cover grommets and put them on wrong....
If you are sure they are on right and are sealing, THEN check for other things.
Old Oct 10, 2004 | 09:21 AM
MrBui's Avatar
Default Re: (specv5150)
sparkplug tube seals not valve stem seals
Old Oct 10, 2004 | 10:44 AM
sickvtec's Avatar
Ight i feel ya, i went through the same problem be4, all you gotta do is go to an auto part store and buy the valve cover gasket set which includes the seals that you need, thats it and you'll be straight!!
Peace!
Old Oct 10, 2004 | 10:50 AM
sohcvtec1995's Avatar
Default Re: spark plugs swimming and coverd in oil??? huh???? (sickvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickvtec &raquo;</TD></TR><TR><TD CLASS="quote">Ight i feel ya, i went through the same problem be4, all you gotta do is go to an auto part store and buy the valve cover gasket set which includes the seals that you need, thats it and you'll be straight!!
Peace!</TD></TR></TABLE>
correct it is a good thing to replace as well. and they are cheap.
Old Oct 10, 2004 | 08:03 PM
MrBui's Avatar
pick up a tube of hondabond too
Old Oct 10, 2004 | 08:44 PM
xerox445's Avatar
Default Re: spark plugs swimming and coverd in oil??? huh???? (n20need4vtec)
yeah hondabond is awsome, so much better then the other Permex ****.
hondabond is expensive as hell tho.
I personally know that hasport when they do anything, they seal it (if required) with hondabond and not rvt.
banks358
Dec 27, 2009 08:26 PM
keyknow
May 30, 2009 08:02 PM
dismemberment
Feb 18, 2009 02:51 PM
respectblades
Apr 2, 2003 06:26 PM
red92s
Dec 14, 2002 11:30 AM
