Timing the Distributor to Adv need some advices + tips
the other day i checked my spark plugs and they are 2months old in the motor...noticed they're hella black...and quite alot of backfire....so it's very obvious that my engine is running pretty dann rich...anyway ( and yes i search...but this timing issue ain't have too much post.)
current bolt on are:
CAI/H/E (custome 2.5")
so i decided yesterday to Advancing my districtor to counter richness of my engine...My question is
how much should i push toward Advance Timing...right now im about im about 1/2 of full lenght Advance timing..
any suggestions or tips will be appreciate
Get a timing light. There only like $30. You can either set it to 16 degrees BTDC or 18 degrees. 16 is stock and 18 is as much as you'll want to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by farside »</TD></TR><TR><TD CLASS="quote">Get a timing light. There only like $30. You can either set it to 16 degrees BTDC or 18 degrees. 16 is stock and 18 is as much as you'll want to go. </TD></TR></TABLE>
wooo...thanx...so i shouldn't advance the distributor timing w/out the gun...do timing gun help adjuste the timing to counter richness or the motor or anyway what is the purpose of the timing gun
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr »</TD></TR><TR><TD CLASS="quote">wooo...thanx...so i shouldn't advance the distributor timing w/out the gun...do timing gun help adjuste the timing to counter richness or the motor or anyway what is the purpose of the timing gun</TD></TR></TABLE>If you adjust the distributor without a timing light/gun, then you just don't know where you're putting it.
But still, even with a timing light, spark timing isn't gonna fix your too-rich mixture.
hmm i believe it does somehow ...advance it..would allow little more air intake ..however it wont counter the whole running too rich problem ...but dont you thoink it will help somehow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">hmm i believe it does somehow ...advance it..would allow little more air intake ..however it wont counter the whole running too rich problem ...but dont you thoink it will help somehow</TD></TR></TABLE>
Uhh....
Rotating the distributor advances/retards ignition timing, NOT cam timing. All that's doing is lighting off the mixture a few degrees in the rotation earlier/later, it's not allowing more air into your cylinders. Advancing may slightly help, but it's not a fix.
Find out why your plugs are fouling out ~ fix the problem, not the symptom.
Uhh....
FlewByU352
Nov 13, 2010 07:27 PM
allnaturalb16
21
Aug 14, 2007 08:57 PM
