Bad wheel bearing???
Old Oct 9, 2004 | 08:30 PM
BrandonClaps's Avatar
New User
Default Bad wheel bearing???
I replaced the drivers side rear wheel bearing about a year ago, and now i'm noticing there is noise like its going bad again or the other side is going bad. I get a humming noise (like i did before) when driving with windows up and everything quite.
I put the car on a lift and moved the rear wheels side to side and in and out and it doesn't have any movement, like if it was a completely shot bearing. How do I find out first, if its the bearing, and which side its on????
Old Oct 10, 2004 | 06:49 AM
Chris F's Avatar
Default Re: Bad wheel bearing??? (BrandonClaps)
When I cooked my front bearings, they made funny sounds when turning right but not left. Or at least the sound changed. Try lifting the car and spinning each wheel?
What year is it? Warranty work rocks.
Old Oct 10, 2004 | 07:44 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Bad wheel bearing??? (ccfries)
depending on how hard you drive the car, wheel bearings can go bad often. I think Willard has replaced his 3 times already
Old Oct 10, 2004 | 08:24 AM
len's Avatar
len
Lift it up and spin it real fast and compare with good side.
Old Oct 10, 2004 | 11:46 AM
uNF$@#!'s Avatar
Default Re: Bad wheel bearing??? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">Lift it up and spin it real fast and compare with good side.</TD></TR></TABLE>
considering itrs have LSDs...how do you plan on doing this?
Old Oct 10, 2004 | 11:49 AM
.RJ's Avatar
.RJ
Default Re: Bad wheel bearing??? (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">
considering itrs have LSDs...how do you plan on doing this?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">I replaced the drivers side <FONT SIZE="5">rear</FONT> wheel bearing about a year ago, and now i'm noticing there is noise like its going bad again or the other side is going bad.</TD></TR></TABLE>
Old Oct 10, 2004 | 11:55 AM
Chris F's Avatar
or you could put the transmission in <U>Neutral.</U> It works too. Maybe a clutch-type LSD would be tougher.
Old Oct 10, 2004 | 01:38 PM
New User
for the second time........ its the rear ;/ I guess i will jack it up and spin it with the wheels on, hopefully i can hear the noise over the brake pads touching the rotor
Old Oct 10, 2004 | 01:42 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrandonClaps &raquo;</TD></TR><TR><TD CLASS="quote">for the second time........ its the rear ;/ I guess i will jack it up and spin it with the wheels on, hopefully i can hear the noise over the brake pads touching the rotor</TD></TR></TABLE>
Well, if you don't know which wheel it is, are you sure?
-Chris
Old Oct 12, 2004 | 06:04 PM
bbqman's Avatar
While you spin the wheel, put your fingers on the coil spring, usually the bearing will transmit the vibration of the faulty bearing right to the coil.
I replaced my right rear at 100k checking it like this.
Old Oct 12, 2004 | 06:23 PM
Fuuma0083's Avatar
Default Re: Bad wheel bearing??? (bbqman)
put your hands on 12 o'clock and 6 o'clock and push and pull, if there is movement its a bad bearing. I have to check them everytime i do an alignment at the shop.
Old Oct 12, 2004 | 06:28 PM
.RJ's Avatar
.RJ
Default Re: Bad wheel bearing??? (Fuuma0083)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuuma0083 &raquo;</TD></TR><TR><TD CLASS="quote">put your hands on 12 o'clock and 6 o'clock and push and pull, if there is movement its a bad bearing. I have to check them everytime i do an alignment at the shop.</TD></TR></TABLE>
Its better if you can catch it before you get a lot of play in the bearing, there are other warning signs, even if you cant hear/feel them, like excessive pad knock-back up front.
honda_driven
Jun 19, 2017 01:26 PM
Jamezvtec
Honda Civic (2001 - 2005)
Jun 11, 2009 04:43 PM
d15b7racer
Nov 16, 2004 04:48 PM
crxtreme27
Oct 3, 2003 02:58 PM
Greyout
Dec 7, 2001 10:44 AM
