h22a auto to manual swap cannot locate VSS (speed sensor)
Old Oct 9, 2004 | 08:09 PM
hondaracer.com's Avatar
Default h22a auto to manual swap 2 hoses on back of tranny near VSS.. what are they? route to cooler?
I'm in a bit of a bind. i've had an h22a in my pc for a while. but auto. decided to go manual. but cannot locate the speed sensors... any one know where they are. its OBD1. there is a plug on the top that has two wires grn/blk and yellow. i believe these are reverse sensor.
Modified by hondaracer.com at 9:49 AM 10/11/2004
Old Oct 9, 2004 | 10:31 PM
Eddiebx's Avatar
the speed sensor is in the back of the tranny, near the shift arm. its had a 3 pin connector. and it is also possible that whoever you bought it from too the VSS out? then you would just have a round hole, about 1" diameter there.
Old Oct 9, 2004 | 11:03 PM
ricepicker's Avatar
Default Re: (Eddiebx)
You can use the one from your stock transmission too. You are correct about the reverse sensor. One should have a male connector and one should have a female conntector.
Old Oct 11, 2004 | 05:20 AM
Default Re:
Okay, got it. i was getting it confused with the sensors on the outer sides of the auto transmission. cool thx. Also.
the hoses that come out under the speed sensor on the tranny... those go to the transmission cooler the same as the auto? sorry. i've searched my **** off but most articals are short on details. its also hard to find a good wiring guide.
Old Oct 11, 2004 | 08:40 AM
Default Re: Re: (hondaracer.com)
mid day bump
landroveraz
Transmission & Drivetrain
Nov 19, 2009 09:33 PM
96honda_EK
Oct 23, 2009 11:07 PM
integra99blue
Apr 10, 2007 01:55 PM
Turbowa
Feb 22, 2005 06:37 PM
