Need some Help on my JDM GSR Motor.. Intake!!
Old Oct 9, 2004 | 06:58 PM
ChadB's Avatar
Default Need some Help on my JDM GSR Motor.. Intake!!
Here's the deal.. I replaced the intake gasket mainfold about 2 months ago, and today it started doing the same thing idleing high then low.. It sounds like the samething that it did the 1st time I got the car... It a JDM GSR swap in a EG.. Also what ECU should I be runing.. It came with P30 chipped.. I am not sure what program it is though.... If anyone can help that would be great..
Old Oct 9, 2004 | 07:06 PM
ekgcool's Avatar
Default Re: Need some Help on my JDM GSR Motor.. Intake!! (ChadB)
I bet you are having a problem witht he IACV on the back side of the manifold. Its near the throttle body, and easy to remove. The hardest part is removing the two coolant hoses on the lower side of the valve. Do this, take off the IACV and clean the two holes. These holes are on the side that mounts to the intake. Clean them with carb cleaner, and let it dry. After, install it and check again. BTW, is you CEL on? If so, pull the code and see if its a IACV code.
KaliMist
May 19, 2014 01:55 PM
phoshyzzle
Sep 24, 2008 08:06 PM
dcdcdc
Aug 1, 2008 07:08 PM
1SlowSi
Feb 24, 2004 06:53 PM
b20turbojason
Nov 4, 2003 04:32 PM
