code 7 keeps coming back after resetting ECU
Old Oct 9, 2004 | 05:21 PM
c for sea's Avatar
Default code 7 keeps coming back after resetting ECU
after i swapped the zc in, i've been getting a code 7 for the TP sensor. that was because I replaced the broken TPS with one from a b18a1. It wasn't set right so instead of going through the hassle of setting it correctly, i just replaced the whole TB assembly complete with the TPS from an d16a6.
the TPS from the a6 was a known working one and never gave a code 7 in the stock Si. so i put it on and reset the ecu and just like that my re-programmed pm6 doesn't give any codes now and the CEL is gone. it's look's like the problem was fixed but after driving the car for a few more days, BAM! CEL and the code 7 is back!
when i turn the car off and turn it back on, the CEL is gone but the code 7 is still there. if i reset the ECU again, the code goes away but just like clockwork, after a few days of driving the car, the CEL blinds me with its jdm amber glare and the code 7 returns. also, forgot to mention, the car will hesitate when this happened. I can have a steady pressure on the throttle, then the car hesistates for a second, then the CEL blinds me, then i look down and away from the CEL and BAM! the code 7 returns!
**** you CEL. i hate that code 7. please help me out guys. i suck at cars.
Old Oct 14, 2004 | 11:44 AM
c for sea's Avatar
UP. PLEASE HELP.
Old Oct 14, 2004 | 04:01 PM
c for sea's Avatar
Default Re: code 7 keeps coming back after resetting ECU (c for sea)
AFTERNOON BUMP
Old Oct 14, 2004 | 04:04 PM
crxgator's Avatar
did you swap the two outter tps wires when you did the zc swap cause of the dpfi to mpfi?
Old Oct 15, 2004 | 11:26 AM
c for sea's Avatar
i think so. i paid someone to do my wiring. maybe i can post a pic.
Old Oct 15, 2004 | 11:43 AM
Nerologic's Avatar
Default Re: (c for sea)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c for sea &raquo;</TD></TR><TR><TD CLASS="quote">i think so. i paid someone to do my wiring. maybe i can post a pic.</TD></TR></TABLE>
im pretty sure thats the problem, Taliban screwed up somewhere....
Old Oct 18, 2004 | 11:45 AM
c for sea's Avatar
nope, i checked it. and looked at diagrams. and you can see where taliban switched them. what else could it be?
Old Oct 18, 2004 | 12:27 PM
crxgator's Avatar
you might have an open/short in the tps wiring...
Old Oct 19, 2004 | 04:45 PM
c for sea's Avatar
damn. double check the wiring and it all looks good. no exposed wiring
Old Oct 19, 2004 | 04:47 PM
dr_latino999's Avatar
Could you verify that the TPS was good before you put it on?
Old Oct 20, 2004 | 05:52 PM
wleach11's Avatar
Did you set the TPS for the correct voltage?
Old Oct 20, 2004 | 06:46 PM
Nerologic's Avatar
Default Re: code 7 keeps coming back after resetting ECU (wleach11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Could you verify that the TPS was good before you put it on?</TD></TR></TABLE>
i ran the new TPS fine without gettign teh code 7, once he got it it started on his car again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wleach11 &raquo;</TD></TR><TR><TD CLASS="quote">Did you set the TPS for the correct voltage?</TD></TR></TABLE>
yeah that was teh next step, but neither of us has a volt metere...lol
Old Oct 22, 2004 | 04:52 PM
c for sea's Avatar
it's gone for now. been a few days since i had a CEL. but i have bad luck and my guess is that the code 7 will come back like it used to.
Gixxerboy02
Apr 30, 2006 01:16 PM
carnifex
Oct 1, 2004 10:28 AM
KiD Fr0m Da 516
Aug 2, 2004 06:36 AM
HondaCutie90
Feb 25, 2002 09:43 AM
