ES LCA Bushing Part number?
Does anyone know the Energy Suspension part number for the large center bushing of the rear LCA? I have the master kit but it doesn't list the parts numbers for each bushing
Thanks! It's the master kit for the 94-01 Integra.
There are two that look similar and can possibly work. I think one may be on the front of the lca and one for the rear because it looks like one is slightly thicker.
I have some 2270's and 2274's that look like they will fit. I also have 2272's but those are for the front. I managed to lose the instruction sheet for teh rear.
Thanks again guys!!
Thanks again guys!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Geno »</TD></TR><TR><TD CLASS="quote">What gen is your integra? I have the master kit for a 94+ gsr/ls I'll look up the bushings when I get off work if we got the same gen tegs.</TD></TR></TABLE>
Did you have a chance to check on teh numbers?
Ok I got the instructions and it says not to remove the center bushing on the rear LCA as that bushing is in set #16-8102(Don't you wish they printed each bushing set on the bag itself?) As for those huge bushings included in the set for the Rear LCA the numbers for them are 3285. I hope that helps even tho I was a little late with a response. Also after calling energy suspension about a seperate matter I asked them if there was an easier way to remove the bushings from the LCA's and they told me that a blue canister torch is the best and fastest way. All you have to do is torch the honda bushing till it gets shiney, at that point the glue holding the bushing into the LCA has melted and you should be able to hammer the bushing out with little effort.
Thanks. I called ES and asked them for the individual # for the large bushing where in the LCA where teh shock connects since there are several that are similar. They said they would email me the parts list, but so far, nothing.
VSBB6
May 31, 2005 11:20 AM
jdmb16acivic
Mar 13, 2004 08:37 AM
