Catalytic converter help with my jdm header?
Old Oct 9, 2004 | 06:44 AM
j_hartwell's Avatar
Default Catalytic converter help with my jdm header?
Mufflertech has the jdm cat made for the jdm itr header but the o2 is place at the rear section of the cat, how many inches from the flange should i have them place the o2 sensor. Also, after installing this cat, will my check engine light go away? thanks
Old Oct 9, 2004 | 09:11 AM
andrew dc's Avatar
Default Re: Catalytic converter help with my jdm header? (j_hartwell)
what year is your car?
94-95 is obd1
96+ is obd2 requiring the o2 sensor on the cat in addition to the one on the header.
Do you know what code you are thowing to cause the CEL?
Andrew
Old Oct 9, 2004 | 02:26 PM
j_hartwell's Avatar
Default Re: Catalytic converter help with my jdm header? (andrew ef)
I have a 99 gsr. My CEL is on cus my o2's arent hooked up right now.
Old Oct 10, 2004 | 07:07 AM
j_hartwell's Avatar
bump
Old Oct 10, 2004 | 01:19 PM
b00sted4dr's Avatar
Im not really understanding your question. It already has an o2 bung placed in the rear of the cat? Thats where the second o2 should be.
First o2 is before the cat and the second goes in after. The jdm itr header has a o2 bung.
Old Oct 10, 2004 | 07:46 PM
j_hartwell's Avatar
Default Re: Catalytic converter help with my jdm header? (That4drGSR)
I thought there was a o2 bung on the header and then one before the cat converter.
Old Oct 10, 2004 | 08:06 PM
Oleg's Avatar
I do not understand your question too. There 2 HO2 (Heated) sensors, one before and one after the cat. There gotta be holes for them already drilled out... Anyways, you said that your MIL is on..... how are you driving your car that, in what condition is your exaust system? (no cat!? )
Old Oct 10, 2004 | 08:16 PM
lanojp1's Avatar
i got two words for ya...TEST PIPE...
Old Oct 11, 2004 | 07:16 AM
j_hartwell's Avatar
no, there is an 02 sensor on the header, then one at the front of the cat.
Old Oct 11, 2004 | 07:19 AM
b00sted4dr's Avatar
Default Re: (j_hartwell)
oh ok, then you need one in the back of the cat. What i did was did it behind the cat, in the b-pipe. It doesnt matter where, just behind the cat.
Thats strange, i have an o2 sensor bung on my jdm itr header??
Old Oct 11, 2004 | 07:20 AM
rgbpmp's Avatar
obd1
o2 sensor in front of cat
obd2
o2 sensor before collector on header
o2 sensor at the back of the cat
Old Oct 11, 2004 | 07:53 AM
j_hartwell's Avatar
Default Re: (rgbpmp)
Thanks for the help! Would the jdm cat for integras from mufflertech.com be a good buy.
Old Oct 11, 2004 | 08:01 AM
b00sted4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_hartwell &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help! Would the jdm cat for integras from mufflertech.com be a good buy.</TD></TR></TABLE>
It would, but it might be a little restrictive. Im have no experience myselft, just feedback from others. Another option is you can go with a carsound.
But yes, both will work.
slowB20ej8
Apr 11, 2008 07:18 PM
Honda_RN
Jan 27, 2005 03:38 PM
dylokjai
Nov 23, 2004 11:11 AM
Slow_Em1
May 9, 2004 05:09 PM
skafia
Jul 24, 2002 09:57 AM
