Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What type of camcorder/system do you use for in-car video?
Old Dec 15, 2001 | 09:58 AM
B18CJDM's Avatar
Default What type of camcorder/system do you use for in-car video?
I've been having problems lately w/ getting shaky video and bad recordings. I am looking to get a new camcorder/video recording system to get better video and was wondering what you guys have found to be the best way to go about doing this. Right now I have a Sony 8mm Handycam w/ SteadyShot that was recently cleaned and I still see no improvement in recording quality, the tape still jumps around just as much as it did before. TIA for helping me decide what step to take next.
Old Dec 15, 2001 | 11:34 AM
SPiFF's Avatar
Default Re: What type of camcorder/system do you use for in-car video? (B18CJDM)
I use a circa 1989 JDM SVHS-C Panasonic on an IO-Port mount attached to the roll bar. I have also used a Sony Digital 8. Neither have had much trouble with jitter.
Old Dec 15, 2001 | 11:45 AM
Apocalypse's Avatar
Default Re: What type of camcorder/system do you use for in-car video? (SPiFF)
This is what I also use, supposedly it has shock absorbsion built in and it seems to work well for me.
Old Dec 15, 2001 | 12:07 PM
johng's Avatar
Default Re: What type of camcorder/system do you use for in-car video? (SpeedFreek24)
I bought a small RCA Pro8, 8mm VHS camcorder used for $100, and it mounted to a I/O Port camera mount. With the included I/O Port mounting strap, it's very steady.
Old Dec 15, 2001 | 12:39 PM
B18CJDM's Avatar
Default Re: What type of camcorder/system do you use for in-car video? (johng)
I'm also using an I/O Port camera mount w/ safety strap on my Harness bar which is the same thickness my roll cage will be (I think 1 1/2"). I think it may be that it is so jittery due to running on such a rough track. Sebring has quite a few really rough corners and that seems to be where it cuts out the most, but I also noticed it shaking alot under braking which my rotors were slightly warped, maybe I have it set too stiff or something and maybe it needs more dampening? I'll try using more padding between the mount and harness bar.
[Modified by B18CJDM, 1:42 PM 12/15/2001]
Old Dec 15, 2001 | 10:24 PM
bussetech's Avatar
New User
I have used an IO Port mount attached to a home-made carbon fiber thing that wraps around the read deck-cover-thing (parcel shelf) in my Integra. I put a folded polish cloth underneath and then additionaly held down the IO Port mount w/ a bungee. It worked very well, but was further back than I would have liked.
Old Dec 16, 2001 | 12:08 AM
XR4racer's Avatar
No matter how you attach it (I use I/O Port as well) the vibration reduction is all in the strap.
Old Dec 16, 2001 | 06:09 AM
siisgood00's Avatar
New User
Default Re: What type of camcorder/system do you use for in-car video? (XR4racer)
How tight is your bungee? Maybe using and adj. length tie down would work better.
Old Dec 16, 2001 | 10:36 AM
Apocalypse's Avatar
I've heard a lot of things about Sebring being very bumpy. This was useful info that we were denied before. I'm willing to bet this is 85% of your problem.
Old Dec 16, 2001 | 11:17 AM
B18CJDM's Avatar
Yeah, I was thinking the same thing after I had the camera cleaned and took it for a test on a road near me w/ similar bumps and still no change. Oh well maybe it's time for a remote video system? lotsa cash.
[Modified by B18CJDM, 12:17 PM 12/16/2001]
Old Dec 16, 2001 | 11:52 AM
bussetech's Avatar
New User
I know a guy who got an X10 cam and mounted it to the front tow-hook on his '95 M3 and put the receiver and his camcorder in the glovebox and it worked really well. Basicly you if you can find a place to mount an X10 cam, the receiver then hook into the line-in on the camcorder and can go anywhere you can get a signal.
Old Dec 16, 2001 | 11:54 AM
B18CJDM's Avatar
Default Re: What type of camcorder/system do you use for in-car video? (bussetech)
Do you know anywhere I can find one of these and any idea on how much they run for?
[Modified by B18CJDM, 12:55 PM 12/16/2001]
Old Dec 16, 2001 | 12:00 PM
bussetech's Avatar
New User
Yeah they're the ones w/ all the really annoying pop-under ads (and a really obnoxious web site):
http://www.x10.com
He got this deal, with the wide-angle lens:
http://www.x10.com/products/x10_vk58a.htm
$99.99
Old Dec 16, 2001 | 04:14 PM
B18CJDM's Avatar
Kick *** thanks man
Old Dec 16, 2001 | 04:19 PM
SPiFF's Avatar
Here is another cool one.
http://www.conecam.com/
Old Dec 16, 2001 | 05:14 PM
AdamITR's Avatar
I.O. Port Mount & Panasonic Digital camcorder.
Old Dec 16, 2001 | 05:22 PM
B18CJDM's Avatar
Well I think I'm gonna just quit my bitchin and deal with crappy video until I can afford something better like this RaceCam
All the other ones don't look high enough quality for me at the time, when I get something it's gotta be the best, so I'm gonna hold out for a few years and then go all out.
Thanks for all your help on the matter though.
[Modified by B18CJDM, 6:26 PM 12/16/2001]
Old Dec 17, 2001 | 05:31 PM
bryante's Avatar
I run a newish Sony DCR-TRV320 Digital8 on a tripod that I bungie into the back seat of my Impala when autocrossing/lapping, and it works fine on all but the bumpiest tracks (like Waterford Hills). The suspension on the Impala ain't exactly plush, and the tripod is pretty cheap and flimsy. I'd have to give a lot of credit to the camera for keeping things steady.
driftnut69
Dec 16, 2010 12:54 PM
JDM Like Whoa
14
Nov 29, 2010 08:09 AM
superg6819
Aug 17, 2009 04:17 PM
mrlegoman
18
Jun 21, 2004 09:01 AM
MintyDip
May 15, 2002 09:42 AM
