RPMS Stick 3-4k in first..then second
Old Oct 8, 2004 | 10:59 PM
zm_dawg's Avatar
Default RPMS Stick 3-4k in first..then second
Well I finally got my car started after 3 weeks of being w/o due to a bad ignitor...and I felt the same problem I had before it died..
Occasionally outta first gear when I accelerate my RPMS stick between 3-4k...I am "forced" to shift into 2nd due to not being able to advance the RPMS...it'll then occasionally do the same thing in 2nd.....so I go to third and then I can go right back into second and it'll take off.......I haven't really found a good explanation or an answer as to what to look into?.....this is a OBD2 JDM GSR.....in my EK.....runnin OBD1 ECU.........
any ideas what to look at.....
Old Oct 8, 2004 | 11:03 PM
rodrez.'s Avatar
Default Re: RPMS Stick 3-4k in first..then second (zm_dawg)
Do you have a friends with the same distributor that you can trade with for testing? I know you changed the ignitor, but a different distributor completley may solve the problem.
Old Oct 8, 2004 | 11:06 PM
IWearMyKswiss's Avatar
New User
Default Re: RPMS Stick 3-4k in first..then second (rodrez)
yea thats what i was thinking,..try another distributor and see if that solves your problem,..are you throwing any codes at all?
Old Oct 9, 2004 | 12:08 AM
zm_dawg's Avatar
no codes at all....it just happens sometimes from a stop in town....if i like normally feather out 1st gear from a stop sign...i usually get the stick after i feel like i let the clutch out early....anyone got a dizzy to borrow for a test drive layin around?
Old Oct 9, 2004 | 10:07 AM
zm_dawg's Avatar
bump
Old Oct 9, 2004 | 10:56 PM
zm_dawg's Avatar
Default Re: (zm_dawg)
bump
Old Oct 10, 2004 | 12:41 PM
zm_dawg's Avatar
bump
scheistermeister
Jan 22, 2006 08:01 PM
TurboRedSi
Dec 10, 2004 08:44 PM
Built B18ABorC
Sep 3, 2004 05:04 PM
EF8_SiR
Aug 30, 2002 07:33 AM
