Dyno'ed my R today
Old Oct 8, 2004 | 07:15 PM
fastvtecCL's Avatar
Default Dyno'ed my R today
well i was alittle disappointed with the numbers. what do you guys think??
*was on dyno jet* see sig for mods..
164whp and 114lbs torque (a/f was high 11's across the board)
i'll post dyno sheet asap
Old Oct 8, 2004 | 08:34 PM
98itr0448's Avatar
Default Re: Dyno'ed my R today (fastvtecCL)
I put down 170 with just an intake and crappy muffler on stock piping. The air temp was 96 degrees though! All dyno's are different. I wouldn't be dissapointed, but not . Get some bolt on mods and things will get a little better
Old Oct 8, 2004 | 08:42 PM
is3oo's Avatar
Yeah, every dyno is different. I don't know by how much, but I'm sure your dyno is reading a little lower. I put down 174 whp practically stock. Only mod was a test-pipe, cam gears and fuel regulator. The stock exhaust really held me back.
Old Oct 8, 2004 | 09:25 PM
Kendall's Avatar
As mentioned, all dyno's are different and vary according to the smallest details such as elevation, temperature, humidity, etc. If you ran a bit leaner, you'd probably throw down a few extra horses.
Old Oct 9, 2004 | 12:06 AM
Bbasso's Avatar
what kind of dyno, those #s are close to my stock...
Old Oct 9, 2004 | 12:58 AM
GOOCH-JDM-ITR's Avatar
your best off comparing consecutive dynos of your car or at least with similar dynos. I heard the dynapak dynos read lower numbers, but it shouldnt matter if your comparing it to your old numbers.
Old Oct 9, 2004 | 05:57 AM
fastvtecCL's Avatar
Default Re: (GOOCH-JDM-ITR)
i'm pretty sure if i got a fuel pressure reg and a v-afc. i can tune the car to run leaner (around 13.5 a/f) and probably get to the 175-180whp range. what should the car be dynoing with my mods ????
Modified by fastvtecCL at 3:35 PM 10/9/2004
Old Oct 9, 2004 | 06:06 AM
ultimatehonda's Avatar
VAFC is your friend If you get the air/fuel tuned you will see a nice increase in HP. With bolt ons on my car I was putting down stock whp....a lil tuning on the vafc and I picked up about 17whp.
Old Oct 9, 2004 | 06:31 AM
RTW DC2R's Avatar
that a/f ratio is killing you.
Old Oct 9, 2004 | 07:12 AM
Ausmith's Avatar
What ECU are you running with a OBDII - OBDI coversion harness?
Old Oct 9, 2004 | 07:17 AM
Bradstard's Avatar
Go and dyno it at P1. He has many different ITR plots there that you can compare it to. Jack =
Old Oct 9, 2004 | 07:28 AM
b19coupe's Avatar
Your mods list includes an OBD2-OBD1 conversion harness, but not what ECU. A generic Mugen or Skunk program? Get something programmable and watch your numbers climb.
Old Oct 9, 2004 | 07:36 AM
fastvtecCL's Avatar
Default Re: Dyno'ed my R today (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Your mods list includes an OBD2-OBD1 conversion harness, but not what ECU. A generic Mugen or Skunk program? Get something programmable and watch your numbers climb. </TD></TR></TABLE>
yea sorry about that, i plan on getting a chipped obd1 ECU.. i'm runing the stock typeR ECU as of right now
Old Oct 9, 2004 | 09:54 AM
Chris93Si's Avatar
:soap box: Does the car feel good? If so fugg the numbers, dynos should be used as tuning devices not as measuring sticks cause they're all different. :soap box:
That being said I think 164 sounds about normal for your mods
Old Oct 9, 2004 | 10:15 AM
DontBlink's Avatar
Default Re: (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">that a/f ratio is killing you.</TD></TR></TABLE>
thats my thought also.
Old Oct 9, 2004 | 10:43 AM
Black R's Avatar
25 Year Member
Default Re: Dyno'ed my R today (Chris93Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
That being said I think 164 sounds about normal for your mods </TD></TR></TABLE>
Agreed.
You may also want to consider getting that 100shot on the car asap... .
Old Oct 9, 2004 | 10:53 AM
B2FiNiTY's Avatar
Sounds fine to me.
Old Oct 9, 2004 | 01:53 PM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: Dyno'ed my R today (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed.
You may also want to consider getting that 100shot on the car asap... .</TD></TR></TABLE>
I agree with you GEE
Old Oct 9, 2004 | 02:14 PM
obd2gsr's Avatar
even though those numbers "sound" low, i bet it'll still run faster than a stock itr dyno'ing higher #'s with that ATS final drive...
i wouldn't sweat it too much.
Old Oct 9, 2004 | 03:06 PM
disordeR's Avatar
Default Re: Dyno'ed my R today (obd2gsr)
that is a little low, but every dyno is different and conditions are always different.
your a/f ratios is a little on the rich side. you could venture 2 points leaner.
Old Oct 9, 2004 | 03:13 PM
Square's Avatar
Cool
Old Oct 9, 2004 | 06:45 PM
Art Vandeleigh's Avatar
Default Re: Dyno'ed my R today (Square)
the a/f seems really rich. my bone stock a/f was in the 17's...
Old Oct 9, 2004 | 06:48 PM
hadboosttroy's Avatar
Default Re: Dyno'ed my R today (Art Vandeleigh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art Vandeleigh &raquo;</TD></TR><TR><TD CLASS="quote">the a/f seems really rich. my bone stock a/f was in the 17's...</TD></TR></TABLE>
um that seems lean even for idle?
Old Oct 9, 2004 | 08:12 PM
fastvtecCL's Avatar
thats pretty damn close to BOOM.... last time i checked 17's a/f is way to LEAN
Old Oct 10, 2004 | 02:10 AM
AussieR's Avatar
LMAO, dude 17:1 = your piston go bye bye. High 12's is good for a DD.
