d series vss in b series tranny??
Old Oct 8, 2004 | 06:21 PM
Rywire's Avatar
Default d series vss in b series tranny??
OK, I just searched... I know ive seen posts on this before But I can find them now.
My friend is putting a gsr in his rex, (same setup as me) and he needs a cable vss. Does the d series one fit? To me it dosent look like it will pull out. If you have a b series cable vss, pm me.
Ryan
PS, I just used the one from my b16, so im still learning in this area.
Old Oct 8, 2004 | 06:30 PM
HamiltonRex's Avatar
Default Re: d series vss in b series tranny?? (droppedcrxsi)
Yes it fits.
I broke my seazed B one when i pulled the engine. and B18C5Crx donated a D series one to the cause .
Its alittle trickier to get in, because the tap that holds it form moving up and down is remoable. so it slides out untill it is tightend. But once tightened its good to go.
-Eric
Old Oct 8, 2004 | 06:40 PM
Rywire's Avatar
Default Re: d series vss in b series tranny?? (HamiltonRex)
Right on man, thanks.
Old Oct 8, 2004 | 06:53 PM
^MikeG's Avatar
i need a b16 cable speed sensor...i have a d-series in right now and i cant go into reverse
how did it work for u?
Old Oct 9, 2004 | 04:13 AM
Default Re: (^MikeG)
Speed sensor has nothing to do with reverse.
Old Oct 9, 2004 | 05:11 AM
T--Rex's Avatar
I just swapped my car from a 88 dx to a b16a, the vss just bolted right up to the new engine.
Heylookits shawn
May 21, 2007 09:36 PM
skunk2powered
Sep 17, 2004 09:44 PM
derekolerude
Apr 11, 2004 04:06 PM
johnzm
Aug 30, 2002 09:32 PM
