help! car idleing up and down
ok i have a fresh built b18c1 i have a skunk2 intake manifold sleeved block O ringed 8-5-1 comp ported head just incase it makes a diff when i first start the car up it runs normal for like 10 secs then it starts to lope the check engine light is on it's marking the iac valve but when i disconect it it deoes nothing i checked my vacum lines and all that and found nothing thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyeg6 »</TD></TR><TR><TD CLASS="quote">it starts to lope the check engine light is on it's marking the iac valve </TD></TR></TABLE>
theres obviously something wrong with your IAC valve or it wouldnt be doing this.
How old/new is the motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill »</TD></TR><TR><TD CLASS="quote">Just replace your IACV and you should be fine</TD></TR></TABLE>
