zc install tired of searchin!!!!!!!!!!!!
Old Oct 8, 2004 | 01:52 PM
itsmebeaner1987's Avatar
Default zc install tired of searchin!!!!!!!!!!!!
got a zc motor and tranny. do i need a zc ecu?or can i run somethin else how hard is it gonns be to put this in my 91 si?cause im not very experienced. any suggestion?any good websites that could help me out?
Old Oct 8, 2004 | 01:57 PM
Malgerus's Avatar
Default Re: zc install tired of searchin!!!!!!!!!!!! (itsme******1987)
Bolt it in. It uses the same mounts and everything as the stock engine. You will have to extend the crank angle wires to reach the ZC's sensor, on the exhaust cam. Also, if you can't find a ZC ECU (PM7), use a 89 Integra ECU (PG7).
Old Oct 8, 2004 | 02:03 PM
What kind of wiring modifications need to be done?
Old Oct 8, 2004 | 03:32 PM
Sho Pow's Avatar
the only thing that needs to be rewired is the dizzy to mate up to the Si's plugs. Everything else just bolts right in. Easiest swap that can be done. You can even use your stock Si PM6 ecu if you want.
Old Oct 8, 2004 | 03:40 PM
NCRXSi's Avatar
Default Re: zc install tired of searchin!!!!!!!!!!!! (Sho Pow)
Tired of searching? You know, I definitely don't mean to be a dick...but there is giga bytes upon giga bytes of information out there on this swap.
I forget how many times i've posted this link in the last couple weeks...ZC Swap
No, you don't have to have the ZC ECU although it is the best...you can run the integra pg7 or you stock Si ECU.
BlueRex1020
Oct 11, 2006 05:03 PM
funkyfreshpnoy
Mar 12, 2006 05:12 AM
4door93civic
Jun 4, 2004 09:42 PM
stock_cx
Dec 31, 2003 10:26 AM
orgasmicsensations
Apr 9, 2003 07:23 PM
